How to setup a HDD from another pc as a secondary drive but not internally
Solved by mariushm,
If you use a Sata to usb adapter cable , or a external hdd cage / bay / whatever it's called - it will be detected as additional drive when you plug the usb cable in.
If you leave it plugged in and turn off your pc and then turn on the pc, the pc MAY try to boot from the external usb device first, depending on how things are configured in bios.
Press DEL or F2 or F10 or whatever when you turn on the pc and simply go to boot order or boot priority and set your internal hard drive as the first device to boot from.
