Search In
  • More options...
Find results that contain...
Find results in...
Would a cancel an RTX 3080 order to get a 6800XT, for Zen 3?
If you're building a Zen 3 system and already have an RTX 3080 lined-up, would you keep the 3080 order or cancel it and get a 6800XT?
24 members have voted
  1. 1. If you're building a Zen 3 system and already have an RTX 3080 lined-up, would you keep the 3080 order or cancel it and get a 6800XT?
    • Based on current information, I would keep the 3080
    • Based on current information, I would cancel the 3080 and get the 6800XT
    • Unsure, I'd wait for more information before acting
With how things are with stock, i would use use the 3080 till reviews came in on the 6800xt. If you end up wanting the 6800xt you probably still could sell the 3080 at purchase price or close to it once you get a 6800xt in hand.
Well I know we should take first-party benchmarks with a grain of salt but it does look like whatever you get. You will end up with a decent card.
I would leave the rtx 3080 order open and try to snatch whatever RX card you want as soon as it's available.
If you manage to get one, you can cancel the RTX order.
If you can't get one, at least the RTX 3080 order isn't wasted.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
I'm currently facing this choice. I'm building a PC around the 5950x. The stores I've been dealing with tell me the earliest I can get a 3080 is in December.
I've been with NVIDIA since 3dfx went out of business. The last time I owned an ATI was a 2D accelerator card. For me to switch is something I've never considered before now.
There's something appealing about having an AMD GPU paired with an AMD CPU. I don't know if that would ever make a difference. AMD is also powering the latest consoles, and I'd prefer to play multi-plats on PC, so maybe that's an advantage.
If the 6800 XT was releasing at the same time as the CPU and I could snag both, it would be a done deal. The delay keeps the 3080 in play. It also lets me see the reviews to be sure the 6800 XT's performance is sufficiently comparable to the 3080.
Here's another question for folks: The 6900 XT is coming in significantly cheaper than the 3090. Is anyone cancelling a 3080 to spend a bit more to grab the 6900 XT?
then get 6800XT
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Currently selling:
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Currently working on:
| i3 9100F || Msi Ventus gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Silverstone essential 400w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
Can we stop the FLOOD of pre-release, pre-reviewed component posts?
Emma : i7 8700K @5.0Ghz - Gigabyte AORUS z370 Gaming 5 - ThermalTake Water 3.0 Ultimate - G. Skill Ripjaws V 32GB 3200Mhz - Gigabyte AORUS 1080Ti - 750 EVO 512GB + 2x 860 EVO 1TB M.2 (RAID 0) - EVGA Supernova 650 P2 - Fractal Design Define R6 - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Logitech G910, G502, G933 - Cooler Master Universal Graphics Card Holder
Plex : Ryzen 5 1600 (stock) - Gigabyte B450M-DS3H - G. Skill Ripjaws V 8GB 2400Mhz - GeForce 8800GTS 640MB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1900 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Dell 19" 4:3
Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM, 512GB NVMe SSD, 1050Ti, 4K touchscreen
MSI GF62 - i7 7700HQ, 16GB 2400 MHz RAM, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti
14 minutes ago, Delicieuxz said:
What would you be inclined to do right now?
I'd be inclined to wait to see how it performs.  Then make a fact-based decision.
On 10/29/2020 at 8:57 AM, SavageNeo said:
then get 6800XT
I just remember something. I bought a 1440p GSync monitor a few months ago. That's a fun wrench to throw into the decision :D
If both cards are at MSRP I personally wouldn't.
I prefer the RTX 3080 to the 6800XT. Less VRAM but most likely better ray tracing performance, DLSS and Nvidia's drivers all for just $50 more.
If we were talking the RTX 3090 and 6900XT it would be a different story.
People would be really hasty to cancel a confirmed 3080 order for 6800 XT, unless the 3080 were coming like a month later *cough eVGA's waiting list cough*
We have no idea if the AMD cards are also going to be scalped or not, but the supply absolutely can't be worse than Nvidia, considering TSMC is involved.  At worst, you could just re-sell the 3080 at cost + shipping to some poor guy who's been trying to get one for months, if the AMD cards are not out of stock.  Canceling an order and then seeing the rich bots buy up all the 6800s and 6900's is going to then make you very, very angry you didn't just have a working high end video card.
