How to correctly format a drive?
Peika
I see so many different methods when I search it up and I don't know what the right one is
I want to wipe my ssd (it's my main drive I have windows on, I have 1 other usb stick)
My preferred method is using a windows USB and just formatting that way, cause I always have a windows USB on me.
Because there are so many different ways, there's no single "right" way, just pick the most convenient one that wipes the data.
Primary PC:
I see. Is it possible to format the disk my os is on? (My boot drive basically everything)
Usually windows can't format the drive it's installed on but if you're just concerned with wiping data you can simply reset windows
A Linux USB is also super easy to create for the same purposes
Primary PC:
