Search In
  • More options...
Find results that contain...
Find results in...
Could I "zoom out" a monitor?
I just got a second monitor, which one that is a bit old, but does the work. Its resolution is 1024x768. My main monitor is 1920x1080. The thing is that the second monitor looks like if it was zoomed in or scaled bigger. I found out that if I change the resolution to a bigger one it zooms out as I would want it, but it does not display some things like the start menu or even the taskbar properly, like if it was displaying something bigger than the monitor itself.
Note that in the right display everything looks bigger.enter image description here
What is the model of the second display, and how do you have it connected to your computer?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro
General Use Mac: Mid 2011 27" Apple iMac
Intel Core i5-2400 (4C/4T), 16GB Various DDR3 1067MHz, AMD Radeon HD 6970M 1GB, 500GB Crucial MX500, 1TB Seagate Barracuda, macOS High Sierra 10.13.6/Mac OS X Snow Leopard 10.6.8
Mac mini (Used as macOS server): Late 2009 Mac mini 3,1
Intel Core 2 Duo P8700 (2C/2T), 8GB DDR3 1067MHz, NVIDIA GeForce 9400 256MB, 480GB OWC Mercury Electra 3G, macOS Sierra 10.12
Storage Server: Clover (soon to be retired after more than a decade of reliable operation)
Intel Core 2 Duo E8500 (2C/2T), 8GB DDR2 800MHz, 160GB Western Digital Caviar SE (boot), 1TB Western Digital Caviar Blue (2x, storage), FreeNAS 11.3-U1
Main Laptop: Mid 2017 13" Apple MacBook Pro
Intel Core i5-7360U (2C/4T), 8GB LPDDR3 2133MHz, Intel Iris Plus 640, 128GB PCIe NVMe SSD, macOS Mojave 10.14
Machines below are in use on a temporary basis for Folding@home work
Folding Box 1: Dell OptiPlex 990 SFF
Intel Core i5-2400 (4C/4T), 16GB DDR3 1333MHz, MSI GeForce GT 710 2GB, 1TB Samsung 860 EVO, Windows 8.1 Pro
Folding Box 2: Lenovo ThinkCentre M73
Intel Core i5-4430 (4C/4T), 8GB DDR3 1600MHz, 500GB WD Caviar Blue, Windows 10 Pro for Workstations
Folding Box 3: Dell Precision Workstation T3500
Intel Xeon X5675 (6C/12T), 24GB DDR3 1333MHz, AMD Radeon HD 6870 1GB, 500GB Seagate BarraCuda, Windows 8.1 Pro
I do not really know the model of the second display, but I connected it via an adapter from VGA to HDMI, as mi PC's GPU does not support VGA
OK. It looks to me like it's a widescreen monitor, am I correct?
Main System: Phobos
1024x768! Rockin' out like it's 1998, love it. I remember my Gateway computer with a Pentium 2 in it having a tough time running Unreal Tournament at 1024x768. Had to run it at 800x600 and in Software rendering too..
I wouldn't be surprised if Windows 10 doesn't support 1024x768
EDIT:
I am incorrect, Windows 10 looks to support all the way down to 800x600 (wow!)
Fun Rig - AMD Ryzen 5 3600  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  PowerColor Red Devil 5700XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair 4000D  |  LG 27GL650F-B  |
Work Rig - AMD Ryzen 3 3200G  |  ASUS X570-P Prime  |  32GB G.SKILL 3200 CL16 4x8GB |  MSI GTX 1650 GDDR6  |  WD Black SN750 500GB NVMe  |  WD Blue 500GB SATA  |  Samsung 860 Evo 500GB SATA  |  Corsair TX650  |  Corsair 4000D  |  Dell S2721DGF  |
Have you tried adjusting the scale? (it's in windows display settings -- idk if you can set it per-display but worth a shot)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Motherboard Tier LIst
PC Troubleshooting
PSU Tier List
You don't need a big PSU
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 512GB SSD - 16GB DDR4 - I lost my pen so I convince myself I don't need it
"Sometimes I just buy computer hardware with no practical use for it, maybe I'm weird"
-Galileo Galilei, 1604
I would be extremely surprised.
windows is all about compatibility (hell, you can't even name a file CON because of legacy printer drivers or something). Lots of people still use 768 displays and there's no real reason to not support it. (even cheap laptops nowadays sometimes come with 768p screens)
PC Troubleshooting
PSU Tier List
Desktop:
Laptop:
EDIT:
I'm not certain what the actual cutoff is, but I've run Windows 10 on devices with lower resolutions. 1024x600 comes to mind, and I think I've done lower as well. It would be extremely surprising to see that Windows wouldn't support low resolutions.
Main System: Phobos
Found out the model. here there is some info. This one says another resolution, weird because even in my monitor settings (not windows but own display's menu) specifies 1024x768 as resolution
The display is just telling you what resolution it's getting from your computer, not the maximum resolution it can show. Do you have a DVI port on your computer that you could use instead? It would look a lot better than VGA and should give you the proper resolution.
Main System: Phobos
I do not have a DVI cable
Newegg
