Search In
  • More options...
Find results that contain...
Find results in...
Is the Samsung 970 Pro better than the 980 Pro?
Based on the specs in the pic, the 980 Pro should be much better, right?  Why is the 970 Pro $120 more?B80301AF-8492-4077-8B55-CF55ED01DFF4.thumb.png.8fbef3a1363e689137bb04a175026228.png
My first build:
  • CPU - Intel Core i9 9900KF @ 4.97GHz
  • GPU - EVGA GeForce RTX 2080 Super FTW3 Ultra
  • Motherboard - Asus ROG Strix Z-390E Gaming
  • RAM - 32GB (4x8) Corsair Dominator Platinum RGB @ 3600MHz
  • Storage - Samsung 970 EVO Plus M.2 NVMe 1TB SSD and Samsung 860 EVO 1TB SSD
  • Cooler - Corsair H100i RGB Platinum SE w/LL120 Fans
  • Case - Corsair Crystal Series 680X (Black)
  • Fans - [3x] Corsair QL120 RGB LED (front), [1x] Corsair QL140 RGB LED (rear), [2x] Corsair LL140 RGB LED (bottom)
  • PSU - EVGA Supernova 1000w G+
  • Monitor - Acer Predator X34
  • Keyboard - Corsair K95 RGB Platinum XT
  • Mouse - Razer Lancehead, Tournament Edition (Mercury)
stock is probably low on B&H so the pricing algorithm set the cost up
https://pcpartpicker.com/product/JLdxFT/samsung-970-evo-10tb-m2-2280-solid-state-drive-mz-v7e1t0baw
here's a more reasonable price for a samsung drive
edit:
scratch that. the 970 PRO was always a really expensive SSD variant and it's being phased out now, but that doesn't mean the price will drop
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Kill Trident Z RGB - Force MP500 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G2 650W - Black and green theme, Razer branwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - Dark moded Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus threadUserbenchmark (Et al.) is trash explained, PSU misconceptions, protections explainedgroup reg is bad
Might be a manufacturing change. 980's might be easier to make a lot of, 970's might of had lower yields. If Samsung thinks they'll be able to make a huge supply of them, lowering the price will likely increase demand.
They look pretty sweet, once they start shipping I plan on picking up about 4 of them for my home and work systems.
AMD Ryzen 5 3600  |  Asus Prime X-570-P  |  32GB G.SKILL 3200 CL16 4x8GBAsus GTX 1660 Super 6GB  | Creative Sound Blaster Z |  Corsair Force GT 240 SATA SSD Boot  |  Storage Spaces SanDisk 480GB SATA SSD + WD Blue 500GB SATA SSD  |  WD Blue 2TB 7200RPM HDD | Corsair RM850x |  Corsair 4000D LG 27GL650F-B  |
Because for 980 Pro they switched from MLC to TLC which helps with cost. Also to align prices more fair vs other and even their own models. The Pro was priced always decently higher.
Ryzen 7 3800X | X570 Aorus Elite | G.Skill 16GB 3200MHz C16 | Radeon RX 5700 XT | Samsung 850 PRO 256GB | Mouse: Zowie S1 | OS: Windows 10
