Transfering HDD with OS to another system
Just now, CitricLemons said:But the problem is that, there is a OS in there how do i remove that?
You dont' need to remove it, just boot from your main drive.
You can remove the efi partition if you want.
By Smurflord
Started
Posted in Graphics Cards0 -
By radosaurus
Started
Posted in Cases and Mods0 -
By The-One-Polish-Guy
Started
Posted in New Builds and Planning5 -
By PepeUYB
Started
Posted in Troubleshooting1 -
By TheLewisS1
Started
Posted in Networking0 -
By Dharshen K
Started
Posted in Laptops and Pre-Built Systems0 -
By lewdicrous
Started
Posted in Forum Bugs and Issues2 -
By Teratos21
Started
By REULINI
Started
By phobersus
Started
Posted in Peripherals0
