Search In
  • More options...
Find results that contain...
Find results in...
HELP! Corsair iCUE H115i RGB PRO XT pumpheader not lighting up!
Does it need to be 5pins Sata to light up the pumpheader of the Corsair iCUE H115i RGB PRO XT?
The manual makes it look like that's the main power cable for it, so it looks like it. Yes.
CPU I9-9900k, Motherboard GIGABYTE Z390 I AORUS PRO WIFI, RAM CORSAIR Vengeance LPX 32GB 3000mhz (2x16), GPU ASUS ROG STRIX GeForce RTX 2070 8GB, Case Geeek A60 Plus, Storage CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR RM650x, Cooling Asus ROG RYUO 240, Displays LG 34UC98-W 34-Inch, 32 inch curved that I can't find the model number for right now, Keyboard Corsair K95, Mouse Corsair Nightblade, Sound AT2020+ USB Mic and Headphones
any ideas what to do? since i have the 650 Thermaltake lite that has 4 pins only, does that mean that i need to buy new power supply? thank you for the reply
