Need PSU and case help for my first build!
lugs
I'm going to build my first pc very soon, so I've been studying up on the ins and outs of cable management and the like.
The specs (or at least the ones that matter right here, anyways) are:
Motherboard: MSI B550 Gaming Edge Wifi
GPU: TUF 3080 OC (when I can get my hands on one)
Case: Phanteks P400A DRGB
PSU: Corsair RM850
After reading the manuals of the aforementioned parts, the only section I didn't really understand is the designation of the modular cables. (attached below)
I know that the 24-pin goes to the mobo power, but the rest is unclear to me.
  1. I know the CPU needs 8-pin, but which of the 8-pin cables? EPS/ATX12V?
  2. If so, I'm assuming the 2x8-pin connector needed for the GPU is the PCIe 8-pin 6+2?
  3. Lastly, my case (P400A DRGB) needs SATA power for the fan controller, is this SATA 3 or SATA 4?
I'm sorry if this post is too long or if I ramble too much. Any help would be appreciated!
The MB takes the 24 Pin ATX AND the 8 Pin EPS.
Yes you need to plug in BOTH.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
1 minute ago, Daniel1 said:
What is your cpu?
ryzen 3700x, at least until 5000 series comes out
If I understand correctly, is this how it works?
MB: 24 pin & 8 pin EPS
CPU: The other 8 pin EPS?
Or does the cpu just rely on the 8-pin already in the MB?
The 24 Pin is just the 24 pin.
The 8 Pin EPS is the CPU power.
You only have 2 power connections on the MB.
24 pin ATX and 8 Pin EPS.
And BOTH need to be plugged in.
Okay I understand. So that means the PCIe 6+2 cables are for the GPU?
Right, exactly.
OH, and you need to use 2X separate PCIe cables for the GPU, not just one with 2 connectors.
Just now, Ankerson said:
OH, and you need to use 2X separate PCIe cables for the GPU, not one with 2 connectors.
So I take two (6+2) PCIe cables, clip the 6 and 2 together properly, then I can pop that into the GPU?
That's power from the PSU, not from the MB.
6+2=8.
You PCIe cables are daisy chained, you will need to use 2 of those. One cable from the PSU end for each 8 Pin on the GPU.
Just tie down the extra 6+2 connections you aren't using.
Yes, I'm aware of that. It's just that the setup for the P400A fans to sync with my MB is confusing for me haha.
11 minutes ago, Ankerson said:
6+2=8.
Oh okay. Thanks man! You've helped a ton haha
OK, have fun and take your time building it.
