I need a case less than 6.5 inches wide. Any suggestions?
PunDaddy
I have a air return right behind my desk. My last pc was a flex build, and for this one I want to be stealthy. So it will just look like a tv on a desk, but I can’t find a pc narrow enough that isn’t a GAMER RIG flex.  The goal is to set the pc on the air return shelf which is 6.5 inches wide. Help?
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Whats the purpose of the PC? If you just want a media device then something like a NUC would be perfect, the new ones even come with a VESA mount so you can mount them straight to the back of a TV or Monitor.
Main Rig:-
Server:-
9 hours ago, PunDaddy said:
I have a air return right behind my desk. My last pc was a flex build, and for this one I want to be stealthy. So it will just look like a tv on a desk, but I can’t find a pc narrow enough that isn’t a GAMER RIG flex. Help?
It will mostly be for gaming... at 4K. 😅
https://www.newegg.com/black-thermaltake-core-g-series-slim-mini-tower/p/N82E16811133314
This is the case I went with my htpc. It's roomy(as far as htpc cases go) inside and it can get plenty of air flow.
If you don't like the looks of that or don't like thermaltake products. Look at any of the silverstone htpc cases. I would have went with one of those for my htpc build, but they were a little more expensive. I particularly liked the raven one.
I looked into this case, but I don’t think I will be able to get a strong enough power supply... I’m probably gunna go with this dirt cheap one from Rosewill it’s 6.69 inches wide which should work
https://www.newegg.com/p/N82E16811147320?item=N82E16811147320
What are you putting in the system? Silverstone makes an 800w sfx psu and they have announced a 1000w one. I don't know if it's available yet though
  • 3 weeks later...
I bought a case the fits atx. ironically... its too tall, but that isnt a big deal as I can change placement.
