Search In
  • More options...
Find results that contain...
Find results in...
cpu temp goes from 37c to 50c when opening web browser
so i recently installed my corsair h100i pro xt last weekend and today i turned it on and for some reason when gaming my temps used to be high 40s low 50s and now its high 50s and 60s and i want to what the problem can be my temps idle fluctuate from high 30s to high 40s and low 50s my temp in icue is 29.70c idle im not sure what that temp is for im assuming the coolant and is that to high?
i just want to know if i need to return it hopefully its just me overreacting because i hate returning stuff it takes to long
the temp in icue seems to keep rising right now its at 30c
Is the pump/fans running? (Check pump RPM see if within spec for that model)
Is there good thermal contact between the coolers cold-plate and the CPU's IHS(heatspreader)?
Make sure the radiator has good airflow, clean if theres dust.
Also it might be software related that in the past the CPU wasnt really stressed but now after some use more programs have been installed and its just working harder.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
the pump is at 2615 rpm i have it set to extreme performance my fans i have on quiet because these fans can sound like a actual jet engine if not, and i thought i had good contact when i installed its on their as tight as possible
Newegg
