Search In
  • More options...
Find results that contain...
Find results in...
Looking for a 17 inch laptop with great Display and Speakers.
Hello there.
As i mentioned in the Title I am looking for basically a TV replacement. Main usage would be to watch Movies and Series. Why is it so hard to find a good Laptop with like integrated graphics that has a great display and speakers?
My mother buys nail polish (hobby) so the more accurate the display is the better. The budget would be around 700€.
4 minutes ago, BaconDragon said:
Hello there.
Because thats not what the masses look for.
I have one that is about 10 years old, ive not seen anything better since then.
My suggestion would be to focus on the screen, then get some external sound solution. As i can ASSURE you you will not find both.
BUT if you do, please tell us. :D
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Well, not unless you want to blow that budget out of existence. The XPS and MacBook lines have crazy good audio, not sure about others.
MacBook Pro 16
i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME - many dongles
