Adding High-Power USB ports to PC for running Samsung Dex
Solved by Senzelian,
How about a USB C PD add-in card.
This specific example can supply up to 93w of power, but you can probably find something that's not so overkill. 20w should be more than enough.
Just search for USB PD PCI-e add-in card or something similar.
Jojo0607 ·
Posted in Peripherals0 -
1
Siper_ ·
Posted in Graphics Cards1 -
ShadeBorderlands ·
1
Champs ·
Posted in Troubleshooting3 -
3
3
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
