HELP HELP HELP Broken HDD and Windows boot partition
SOLVED! at a cost..
I had to go with the nuclear option, that being to reinstall Windows.
I took the SSD out and put it into another computer to back up some important stuff, all went smoothly.
1. To fix the corrupted USB I just ran the Windows thing on it again.
2. When I went to install Windows, it said my drive needs to be GPT and not MBR.
3. I followed this guide but that involved wiping the whole drive.
4. In a comment on that video I saw someone suggesting to create the partitions manually, something I was hoping Windows would do.
5. Not trusting Windows, I did so according to this guide Method 2, Step 3. (Which I was unable to do before due to "not enough reclaimable bytes" supposedly.)
IT WORKS! All of my original data is gone but oh well, the price of Windows.
If you currently have this problem and this post just popped up in google, hi!
