Question about motherboard and rgb fans.
2552Jordan
Motherboard theres 2 Argb headers. I am going to buy 6 Cooler Master MasterFan MF Halo 120 mm. I will have a 6 port hub for all the argb connectors.
However can i connect the hub to just 1 of the argb headers or should i find a splitter between the two plugs?
Thx
You can connect the hub to 1 header and keep the other header free for future stuff.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Ok thx just wanted to check since i didnt want to short out the board.
