Search In
  • More options...
Find results that contain...
Find results in...
I need help with my ARGB fans and mobo header
Hi guys, Im making new build and My case Requires 17 , but Im gonna put only 10 + AIO cooler (3 120mm Fans)  , but I have Got a Problem And that is My Mother board Has only 2 Argb Header , So Im not sure how to Plug all These 13 Argb fan Pins
Theres my build
AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor
Enermax Liqmax III 360 ARGB 72.1 CFM Liquid CPU Cooler
ASUS ROG Strix X570-E Gaming
G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory   X 2
Western Digital Blue 500 GB M.2-2280 Solid State Drive
Samsung 860 QVO 1 TB 2.5" Solid State Drive
Thermaltake Core P8 TG ATX Full Tower Case
Asus ROG Strix 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Cooler Master MasterFan MF Halo 47.2 CFM 120 mm Fans 3-Pack  X3
, but my mobo manual says : The argb header supports wS2812B argb Led Strips (5v/data/ground) with maximum power rating of 3A (5V) and Maxixmum Of 12 LEDs.
 So Im asking If I use Cooler Master ARGB 1-to-5 Splitter Cable
Or a Hub Can I run All These Fan (except AIO cooler fans) With One header? Or Is There Any other Way?
-> Moved to Air Cooling
Couple of things. First, no system requires 17 fans. None. If you exclude fans of PSU and GPU, even fully custom water cooling would use 9 fans. Or under 10. And even then its because of aesthetics rather than performance. Generally systems use 3-7 fans, and the amount depends highly on what case and what kind of component cooling you got going.
Second, you are probably going with the case because of looks. I would advice against going with case like that unless you are gonna do full custom loop in future. Those kinds of cases rely much on the fact that components are cooled by radiators. Your GPU will be having some issues. Unless you are going with the airflow shown in that product pic (top intake). The front intake in that pic is feeding directly to side exhaust fans, and I'd be surprised if some of the air coming in from there reaches GPU.
But to your question. Headers are 3A per. Halo's are 0.55A (0.8A max). Just 9 of them will get you to 4.95-7.2A. Adding 3x for AIO, 0.36A each si total 1.08A. Plus the one unknown fan. So nope on what mobo can power. You need RGB hub with extra SATA power. For example from CoolerMaster https://www.coolermaster.com/catalog/coolers/rgb-accessories/masterfan-argb-and-pwm-hub/
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
 I changed Case , Instead of P8 Went to lian Li. Still tahnk you , Im not worried about fans Mostly argb Stuff Since max Led one header can handel is 120 Leds. and Saw Some revie on the Lame Aio cooler , it was bad and after some time It gets gunk on gasket So I went With Ek 360 Aio.
You can daisy-chain multiple fans to you header.
Even for the Enermax Liqmax III, you can chain the 3x ARGB cooler fans + an extra 2 or 3 case fans to one ARGB header.
Then you can chain the remaining 6 or 7? to the second ARGB header.
You can use an ARGB hub (or 2 hubs)...like this.
Up to 6x ARGB fans.
https://www.coolermaster.com/catalog/coolers/rgb-accessories/masterfan-argb-and-pwm-hub/#item1
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz (still tweaking) -- i7-6800K
  • Gigabyte Z390 Aorus Master -- ASUS X99 Deluxe
  • Sapphire NITRO+ RX 5700 XT Special Edition -- 2x Sapphire NITRO R9-Fury in Crossfire
  • 32GB G.Skill TridentZ DDR4-3000 CL14 (16GB TridentZ RGB + 16GB Red/Black TridentZ)
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO + 1TB Intel 660p NVMe
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Phanteks Enthoo Luxe Tempered Glass Edition
  • Ekwb Custom loop
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
Intel Z97 Rig (Secondary)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
