Search In
  • More options...
Find results that contain...
Find results in...
Sony Vegas keeps crashing and failing render
Ok so I do video editing as a hobby with Sony Vegas and with my (as I would want to believe) higher end hardware, I like to click the flashy, black on grey, 4k 59.9 fps button. While this is usually fine for some shorter (around like 30 seconds) videos i made for Youtube, I have recently done a math project where I needed to make a video (This one is around 1 min+). When I tried to render in my fancy 4k 59.9 fps video quality, it didn't work. While my temps weren't great (79-85 degrees C usually), they were still below AMD's recommended max temps. So then I relented and switched to 4k 50 fps and it worked! sorta. Some days, it worked just fine, while others, not even a chance. While this isn't the end of the world for me and my gaming is still really stable, I want to get the most out of my hardware. Does anyone have any troubleshooting steps I can take to make sure everything still works as intended? I have memtest on a USB ready.
Some more info:
Yes, my GPU and CPU are both overclocked and my RAM's xmp profile is on.
Only once was overheating a cause for a failed render.
I found a dead fly in my psu. I dont think this is the problem as i dont know how long that little bug was there and my system was running just fine before.
RAM sticks in proper slots.
tried updating AMD chipset drivers from dragon center.
MB drivers not up to date.
GPU drivers up to date.
Cleaned out dust from PC a few days ago. PC not on the ground
Project file is on my hard drive.
Using Sony Vegas 14.0 (Can't get latest version because I kinda obtained this software through morally questionable ways)
Sorry if my post is a little bit of a eyesore. Thanks for reading and hopefully replying
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
Is it working if you render in a lower resolution? Just curious.
Quote
You monster.
春の八王子、君はもういない。独り八王子、君はいないから。春の八王子、君はもういない。独り八王子、君はいないから。
You monster.
usually
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
I would record the issue and post it because it's kind of confusing.
this is why i am asking. it crashes inconsistently and fails with no reason
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Maybe it's limited to Vegas itself.
If it's cracked or if you obtained it in some other dubious manner then this is why it 'usually' works.
I used a cracked Adobe package and the thing was... questionably stable. I would perhaps look into the software itself.
Not being able to update to the latest build can cause bugs in these sorts of programs.
