Search In
  • More options...
Find results that contain...
Find results in...
Screws that came with motherboard seem too small for my WD_BLACK SN750 Heatsink.
Title says it all. Anyone else know this problem and suggest where I can get the right screw? Thanks.
The heatsink shouldn't have anything to do with it. The screw holds the PCB of the drive against the standoff, it shouldn't touch the heatsink.
Picture would probably help explain what you mean.
https://imgur.com/a/DOZIhYS
https://imgur.com/a/cXL0UTZ
Whats happening basically for me is that the screw really can't reach the hole. Or it can but it won't screw in. I'm sorry if I'm doing something stupid I'm new to PC building. Thank you
It looks like there should be enough room for the screw to clear the heatsink, are you sure you are trying to use the correct screw? It should be a very small one. It would help if you pictured the screw that you are trying to use, preferably when you are trying to screw it in so we can see if it is the correct screw.
Welcome to the forum! When you are replying to someone, don't forget to either quote them using the Quote button below their post, or tagging them with the @ symbol followed by their username, like @Bigshotinred. This way they can get notified that someone responded to their post.
https://imgur.com/a/smNTIpr
@The_russian This is what came with the board.
The screw should have come in a little baggie with the motherboard contents. Check the box.
edit: That is the screw. The M.2 drive should be under the head and the drive flat and even across the mainboard.
- If it ain't broken, don't fix it! -
- Your post codes and beep codes in the drop down below.
It's a thumb screw. The M.2 drive PCB should be flat to the botton. The screw head on top of the pcb of the drive and the tall part is the thumb finger grip. We call it a thumb screw basically. No tool needed.
You can see the M.2 drive on an angle in the first pic I posted above.
@The_russian @ShrimpBrime @spartaman64 I see. Thank you guys. I’m sorry about wasting your time there i’m still learning.
welcome :)
