Search In
  • More options...
Find results that contain...
Find results in...
Rx 580 no second display . Please help before I brake this card
I’ve made atleast 6 post about this , to absolutely no help . Just people going oh shit eh mine dosnt do that ..
The gpu worked seemingly fine he first 2 days, after the second display would have to phase itself into existence. It would start black then static and then flash for 5-20 mins and then would work without issue the rest of the day.
Corsair cx650 watt power supply and it’s what I suspect to me my problem. While playing rocket League the card only draws 127w and nothing more . So theoretically it’s the power supply causing my issues?
But after reading thousands of post about things that arnt really even related because I’ve gotten ZERO answers. The forums say that I can only use the HDMI port OR the dva port not both . But I get both working fine for the rest of the day , it’s just the initial start up...
The monitor would do something similar when I had a 1050ti , it would go black for a few seconds , then come back and have pink and green lines all over the screen . I would restart the pc and the issue would go away.
What is my issue ? What the hell do I spent more money on to try and fix ? I’m honestly getting tired of typing this post out EVERY morning while sitting here waiting for my screen to blink into existence..... so please someone just help me
Have you tried clearing the motherboard CMOS? Seems to be related to something other than the GPU if you've had issues using multiple monitors across several graphics cards.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
Try to swap the cables to both monitors, but it sounds like the monitor itself might be the problem.
F@H
Desktop: i7-5960X 4.4GHz, Noctua NH-D14, ASUS Rampage V, 32GB, RTX2080S, 2TB NVMe SSD, 2x16TB HDD RAID0, Corsair HX1200, Thermaltake Overseer RX1, Samsung 4K curved 49" TV, 23" secondary
Mobile SFF rig: i9-9900K, Noctua NH-L9i, Asrock Z390 Phantom ITX-AC, 32GB, GTX1070, 2x1TB NVMe SSD RAID0, 2x5TB 2.5" HDD RAID0, Athena 500W Flex (Noctua fan), Custom 4.7l 3D printed case
Dell XPS 2 in 1 2019, 32GB, 1TB, 4K
GPD Win 2
Might be a dead end, but are your chipset drivers up to date?
Yes everything’s up to drivers are up to date , I’ve tried every combo of cords , just the tv works and when I try just the monitor, it’s still staticky and flashy @Kilrah @TheInfinityBacon
Then the card is just fine but that monitor is gone.
F@H
GPD Win 2
@Kilrah @TheInfinityBacon @WaggishOhio383 Ouhkay so update , the power randomly went out across the entire city.... I was working on the computer , just streaming . And the power flickers and comes back on 30 secs later . Now the second display is 100% not registering at all . When I boot up it shots the acer logo for my mobo , I can boot into bios and see the bios on that monitor, but the second it gets to windows , it’s not detected anymore , and it dosnt even phase into existence. It’s just gone . I’m writing this quickly before swapping that monitor to another computer and seeingn if it still works on that computer. Will update again . But I just figured this might be useful info in actually fully diagnosing my problem.
