Search In
  • More options...
Find results that contain...
Find results in...
Is my timespy score too low on default on Rtx 3090?
Hello. I have Rtx 3090 Gaming Pro and 9700K stock. I have 17500 points in timespy graphic score which is low because on reviews i should be get 19.000+-. Powerplan is to balanced.
WHen i change powerplan to fullperformance i am getting 19.000 points and its fine. I have newest nvidia drivers. Any ideas?
In port royal i have 12.500
My scores are normal with balanced power plan in:
Unigine Superposition 1080P EXTREME ,12154pts<- normal, 3dmark extreme 23,500 gpu <--normal
Only in timespy i have 1000 points gap between balanced vs max performance.
During test cpu dropping random clocks in timespy on balanced. In max performance is steady 4600mhz so thats why i think i have lower score with balanced.
In max performance i have 19000 gpu score +- in time spy.
Games running ok with balanced.
I have 9700K on stock
PC
Aorus Z390 Pro Gaming
2x16 GB DDR4 GSKILL
9700K stock
Seasonic 750W Ultra Titanium Plus Prime
Windows 10 up to date no programs in background
Can someone with Rtx 3090 share result with balanced?
Just did Timespy in Balanced my GPU Score is 20942
10700k
MSI Ace z490
MSI Gaming X Trio 3090
So what's the problem?
Variance between power plans is normal. I get 1000 point difference too.
You can search benchmark results for your exact hardware including clock speeds. If you are within a few hundred points of everyone else it's fine.
