Search In
  • More options...
Find results that contain...
Find results in...
Is it normal to get 75 C in furmark, while getting 84 C while gaming?
CPU: Ryzen 5 3600 @ 4.5ghz 1.288v     RAM: 16gb G.Skill 3600mhz
GPU: XFX RX 580 8gb                            Motherboard: MSI B450 Tomahawk Max
CPU Cooler: Hyper Evo 212                   PSU: Segotep 750W 80+ Gold
Depends on the setting and your airflow config
Yes,The temps are very normal.
A GPU is not a human :D
A PC Enthusiast since 2011
AMD Ryzen 5 2600@4GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2040MHz Memory 5000MHz
Cinebench R15: 1382cb | Unigine Superposition 1080p Extreme: 3439
Yeah!  I have the same card.  It seems that 90C is the limit and anything past that will shut down the display.  I put in fans to bring my temps down for this GPU.
84C is a bit on the high side. Try re-paste it, and undervolt your GPU.
I did re-paste
Still no word on current airflow config.
What case?
What fans? What position?
Cpu? Cpu cooler?
What case?
Cpu? Cpu cooler?
I don't know what case. It's really old though. I have a 200mm fan blowing fresh air into the GPU cooler fans and another 200mm fan blowing hot air out.
Cpu is ryzen 5 3600 overclocked to 4.5ghz at 1.288v. Cpu cooler is hyper evo 212 with two 120mm fans blowing air through and another fan pulling air out.
How about some pics?
I just undervolted it, but the temps are still around 85 C at max with fan speed at 100%. Not gonna take a pic
Bummer Ive never seen a case with a 200mm fan for exhaust.
What happens to the  temps with no side panel?
To be honest, I took a chance on buying the RX 570 because I was curious about the state of Radeon after I swore them off while they were still owned by ATI.
It's a nice priced middle of the road GPU but if I were to get something else not budget and better it would be NVidia only.  Those GPUs always had a reputation of running too hot for me.  I had to install two intake fans and an exhaust fan just to get normal fans.  I don't think Nvidia would have given me these problems.
If you want to get the temps down you can buy case fans from Amazon, but warning, some of those are loud.
Found the problem. My sound card is blocking the exhaust fan on the GPU cooler. With my sound card removed, I'm getting around 78 C max.
Should I move my GPU to the bottom PCIE 16 slot, then move my sound card and my WIFI card to the upper two PCIE 1x slots? Am I suppose to use the lower PCIE 16 slot for my GPU?
Sound card?  Isn't the sound card installed into the motherboard?
I have the sound blaster z sound card71JPZSuUsLL._AC_SL1500_.thumb.jpg.31110f0babf6fbc59c9237ee8965caf1.jpg
Newegg
