Newly upgraded system freezing, could it be the motherboard?
AB00
PC build: https://pcpartpicker.com/user/AB00/saved/4rKF8d
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler
Motherboard: Asus
PRIME B550M-A Micro ATX AM4 Motherboard
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Storage: Samsung 850 EVO-Series 250 GB 2.5" Solid State Drive
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive
Storage: Seagate Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 1070 8 GB FTW Gaming ACX 3.0 Video Card
Case: NZXT S340 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA NEX 650 W 80+ Gold Certified Fully Modular ATX Power Suppl
Monitor: MSI Optix MAG322CQRV 31.5" 2560x1440 144 Hz Monitor
system: window 64x
first i used Crucial Ballistix 3600 MHz DDR4 DRAM 16GB (8GBx2) CL16 BL2K8G36C16U4R and the pc would freeze even on default speed, i even clocked down from 2666 default to 2133 and it still freezes
then used my old rams HyperX FURY Black 16GB Kit (2x8GB) 2133MHz DDR4 Non-ECC CL14 DIMM Desktop Memory (HX421C14FBK2/16) worked without freezing on default speed (2133)
tried newer rams: Corsair CMK16GX4M2Z3200C16 VENGEANCE LPX 16GB (2 x 8GB) DDR4 3200 (PC4-25600) C16 1.35V for AMD Ryzen freeze on default speed (2666)
Can someone help me figure this out?
Bios is updated, The Freeze start with a sound cut only, less than a minute later everything else freezes, it happens gaming or just browsing, it freezes more often when gaming
what are possible causes for this?
Thanks
Sounds like your CPU cant handle the Speed for some Reason. Although 3600 the optimal speed is.
If you just bought it, RMA it and tést a new one. I doubt its the Mainboard.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
but why would it also freeze after downcloaking to 2133 with the the ballistic ram? is there any method i can verify that?
Have you terminate any other freeze reasons? Like temps ect.?
Yes, i used CPUID HWmonitor and up until the freeze all is well
Did you test each DIMM one by one, slot by slot?
