Search In
  • More options...
Find results that contain...
Find results in...
Screen goes black and 100% fan speed
Spec:
Ryzen 5 3600
Vega 56 gigabyte reference
Corsair CV650
This only occurs while playing games or heaven benchmark. After I replaced thermal paste it does that consistently after about 10 minutes. It used happen before but not as frequently. It's not a thermal issue. I can run furmark at 73-75C without it happening.
 - DDU
 - revert to an old driver
 - make sure its not hardware, did you overtighten the screws?
-  undervolt/ underclock
that psu with very power hungy card can be the problem. CV650 is not bad but it is bad for Vega or RTX 3000 series since thay use a lot of power and have power spikes.
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
1 hour ago, The Sloth said:
 - DDU
Ive ddu and install older driver but no luck. Maybe it's hardware. Which screws should I check?
3 hours ago, MezVod said:
Spec:
Ryzen 5 3600
Corsair CV650
Im sure you know but thats your PC crashing, if you say its after you replaced the thermal paste then its probably doesnt have good enought thermal contact, did you also replacce the CPU thermal paste, because then it would explain wh furmark is running fine.
what is happening is that the CPU isnt cooled properly so it starts to thermal thruttle, but then after thrutteling its still to hot so it thruttles again then its still to hot so it freaks out and shut it self down while ramping fans up to 100% on everything to cool everything because its warried about the rest of the systems thermals
