Custom cables or just get cable management combs?
5 hours ago, DankDoodles said:I want to get cables from @CableMod, but I have a hard time finding what wires I should get. I want black sleeved wires with black cable management combs, mostly because of the combs since it will have the wires more straight. However, I don't know if it would be better to just use the cords that are included with the power supply then buy cable management combs to put on the cables.
What should I do?
Hopefully some of the information about my pc specs will help:
Motherboard: Asus ROG X570 Crosshair VIII Hero
CPU: AMD Ryzen 5900X(I hope)GPU: ASUS TUF Gaming NVIDIA GeForce RTX 3080
Power Supply: ASUS Rog Thor 1200W Modular RGB
@DankDoodles the stock cables from that PSU are sleeved, but they're also very thin (I think 1.8mm if I remember correctly)? You could go with the stock cables, but we also support replacement cables for your unit as well if you would like colored options instead.
Our RT-Series kits will have everything you need for this setup.
https://store.cablemod.com/products/?filter_series=rt-series-asus
