Color Accuracy for Adapter.
Ero
Hello. My gpu only have 3 ports and I want to pick a 3rd monitor but its 3rd port is a DVI-D and I want to convert it to either HDMI or VGA.
Which one will have better color accuracy cause its important for my work and I'm using this monitor if you need it.
I can buy this adapter for DVI to VGA:
And I could only find passive adapter for DVI to HDMI.
Thanks for help
Thanks for help
Don't use VGA. Use a simple DVI to HDMI adapter.
Simply put, you'd want to do signal converting as small as possible, or even not at all, to prevent quality loss.
DVI-D is a digital signal-only, so go for HDMI. You'd just convert it from digital to analog if you go for DVI-D to VGA, which is ridiculous to do anyway lol
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
Intel Xeon E3-1225 v2 || ASRock B75M Motherboard || MSI GeForce GTX 1650 Gaming X 4G || Hynix 2x8 GB DDR3 1600 MHz RAM || 480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD || be quiet! System Power 9 500 W PSU || Cooler Master T20 CPU Cooler || Samsung S19D300 Monitor || Fantech X6 Knight Mouse || VortexSeries VX7 Pro Keyboard
Samsung Galaxy A34 5G
8GB RAM, 256GB Internal Storage, 128GB SanDisk Extreme, and you could find the rest of the specs on the interwebz lol
Lenovo ThinkPad L390 Yoga
Intel Core i5-8365U || 8 + 16 GB DDR4 (don't ask, gf bought me the 16 GB RAM as my birthday present lol) || Samsung 256GB SSD
Personal Server: CasaOS, Home Assistant, ESPHome, Jellyfin.
AMD E-350 || 3GB DDR3 || 120GB random SSD || 1TB Toshiba HDD
Audio
Redmi TV Soundbar || KZ EDX Ultra + KZ APTX Bluetooth Module || JCALLY JM6 CX31933 DAC
