PLS HELP FIRST BUILD DOESNT TURN ON PROPERLY
Tucci149
its plugged in the left 4 pin conector seems to be a bit lower than the other one, idk if that means anything
hey ill be right back, I accidentally spilled my office tacks and my son stepped in them
alg
Just now, made zos ion said:
yes try that
Its gonna take me a couple hours maybe :) :(
2 minutes ago, Tucci149 said:
should I take everything apart and start over?
It can’t hurt. But you don’t need to build inside the case for now. You can build it outside the case (like on top of the motherboard box) for now and then transfer it when it is working. Doing this will ensure that there is nothing you overlooked when building it. When it is disassembled, carefully look at the cpu to make sure no pins are missing or damaged.
I don’t have too much experience with troubleshooting, but it sounds like a power issue through your motherboard and will likely require a rma if that’s the case. Do you have any other motherboards (and CPUs if need be) available to test with if rebuilding does not work?
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
Oh, I wish I could help you out with that.
I tried turning it on again and the mobo led beeped green? they are supposed to be orange, is it broken?
No other motherboards or cpus unfortunately ill rebuild it outside of the case
I'm going to bed, its 2:01 am, i'm barely awake right now. I'm sorry ill try to help tomorrow once i'm more awake. BTW good luck I hope your PC gets online.
Thanks!
I'd test the PSU first
http://support.antec.com/support/solutions/articles/1000015319-is-my-power-supply-dead-the-paperclip-test
TLDR: You'll need to switch on the PSU and connect the 16th and 17th pins on your molex connector with wire (like a paper clip) and see if it turns on.
If that works, then I'd disconnect everything else and only leave the RAM and the CPU in and then see if that powers on. If that works, work your way up in terms of connecting things till it doesn't work
what molex connector?
2 minutes ago, BillRizer said:
My bad. I meant the 24 pin connector to your motherboard
so i need to have the 16th and 17th pins of the mobo connector touching a paper clip ?
and see if what turns on?
don't you want me to try all the components outside the case first?
Im basically almost done it? ill test the psu iif thats what you want me to do first tho
Yes. Make sure all the other connectors from the power supply are disconnected from everything else.
Try the PSU first
