Search In
  • More options...
Find results that contain...
Find results in...
PLS HELP FIRST BUILD DOESNT TURN ON PROPERLY
Hi all, I need help.
I just finished my first build, when I turned it on the LED on the mobo flashed for a second before turning off completely, the LED on the GPU not working and not a single fan in the case, cpu cooler or gpu fans are working. the ram rgb remains on while everything else is off. idk what to do pls help.
more info: psu plugged into MOBO, CPU and GPU, fans all plugged in, ssd in slot cpu cooler connected. Im guessing this is either a PSU or a MOBO problem. Im preety  sure I plugged everything correctly aswell: mobo power cable with notch to the right and cpu power cable notch to the top.
1 minute ago, made zos ion said:
maybe a psu problem?
Maybe maybe, or maybe a mobo problem aswell im not sure. might be that I plugged something in wrong aswell. idk
does it beep when you start it up?
the mobo led beeps and then no more ram lights up
Just now, made zos ion said:
question, when building did you use an anti static bracelet?
no, I had shoes on and build on a mouse pad on top of  wooden table, the floor in my room is wood, outside of my room its carpet
What are the specs of your computer?
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
Ill send in a min, sending photos of the build rn
static electricity I believe is the cause
I asked on this forum and they said I didnt need one.
Highly unlikely. Static electricity is a very small risk now a days. Unless op is in an area prone to high static electricity, the cause is almost certainly something other than esd.
you dont
PSU Tier List
SSD Tier List
PARROT GANG
 The humidity of your environment will also affect how much static electricity you're going to build up. If your room is dry, you're at a greater risk. ... As this video shows, PC components can definitely be rendered useless by static discharge. But even the testers there say they never wear an anti-static band.
I live in a preety humid city and its rained today, my house is not that well insulated either
oh, could be a defect in the motherboard, but thats highly unlikely. hmm trying to think..
Can you confirm that ive plugged everything correctly please? im preety sure I did but just to be sure
The ram turns ON after I turn off the psu and after about 5 seconds it turns off
