Search In
  • More options...
Find results that contain...
Find results in...
Today I went to my tough book, I log on at least every day. But today something happened, I turned it on and it said configuring updates. so I sat there for about 30 minutes watching the screen, when it said it was done it loaded genuine windows 7 professional, the OS I use every day. But when it booted it showed a blue screen saying my PC was out of date and no longer supported, I know it was discontinued but, still. So I then checked the specs of my PC to see if I could upgrade to windows 10, but the requirements are to much for my pc, so I cant upgrade or it could damage my laptop. I need help asap!
Just press Don't Remind Me Again.
And if the requirements for Windows 10 are over your PC specs, installing Windows 10 isn't going to damage your components. It's just not going to be a great experience. But Windows 10 can run on anything like a Core 2 with just 2GB of RAM. Again, it can run it, might not be as smooth as one would like.
AMD FX™ 6300 @ 3.50 GHz | ASUS M5A97 R2.0 | MSI GTX 550Ti | 16GB Kingston DDR3 | Samsung 850 EVO 250GB | WD 750GB | Antec 300 | ASUS Xonar DG | CoolerMaster Hyper 212 Evo | OCZ 600W | Windows 10 Pro
Sony MDR-V250 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5
Intel Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 8GB DDR4 | Windows 10 Home | ASUS Vivobook 15
Intel Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance DDR3 | Samsung 850 EVO 250GB | macOS Catalina  Lenovo IdeaPad P580
AMD Phenom™ II X2 550 @ 3.10GHz | Gigabyte GA-MA785GM-US2H | XFX Radeon HD 4870 | 4GB Corsair XMS2 | WD 250GB | Thermaltake TR2 500W | Windows 10 Pro
iPhone 6s (iOS 13.7) | iPad Mini (iOS 9.3.5) | Samsung Galaxy S5e (Android 10)
Your PC isn't going to stop working, it's just letting you know that Windows 7 is entering the EOL stage of development. You'll still be able to use your PC just fine, but you'll no longer get software updates.
Always remember the 80/80 rule of project management. That is, the first 80% of the project takes 80% of the time, and the last 20% of the project takes the other 80% of the time.
7 minutes ago, made zos ion said:
I need help asap!
Time to buy either a new laptop/desktop, ensure your Win7 is solidly locked down, or switch to Linux.
So rise up, all ye lost ones, as one, we'll claw the clouds
oh, thank you for your help.
but there is one problem, my tough book has 1 gig of ram
I also have a centrino cpu installled
Ouch, can you get more RAM for it? Probably not worth the cost, buy even ancient laptops support more than 1 gig of RAM
I could try, do you have any stores I could buy from?
newegg, BUT you'd have to know the exact model of your laptop, and how the RAM is installed before you start spending money
ok, I have 1  stick installed, it uses a weird slot type, the "pins" are weird too
How old is this Thoughbook? It still has the Windows logo on the keyboard from like the 9x to Me days.
windows NT logo
or xp logo
not really sure
1 minute ago, made zos ion said:
windows NT logo
Throw it away, the cost for the RAM exceeds the value of the laptop
hmm...
What model Toughbook? This will help us help you
CF29
originally running xp
ok I just checked the specs virtually instead of physically, its still bad but a little better. 1.50 gigabytes
https://www.bobjohnson.com/how-to-upgrade-the-ram-in-a-panasonic-toughbook-cf-29/
Looks like only 1 slot that you can access to upgrade the RAM on.
https://www.memorystock.com/memory/PanasonicToughBookCF29.html
It's already maxed out.
Time for a new system.
ram is locked under an aluminum plate with 4 screws
I think I could possibly mod it to have a higher performance, I have the tools and knowledge to mod it, but all I would need would be the parts and I think I could get the parts.
Nope, RAM is already at max, as per my previous links. That laptop is as good as it's going to get.
If you want to still get updates and a usable experience try some lightweight linux
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
Couldn't he "upgrade" to 8.1 somehow?
I mean 10 will run like shit on this and you know it...
Otherwise I prob just wouldn't do anything...
Also, OP, I'm sure you knew about the EOL of win7 so what was your plan anyway?
It just seems you're confused by that screen... I mean yeah, this means no more updates, your call, either update, don't update, or get a new laptop (alternatively win 8.1 may be an option tho idk if that's any better)
RYZEN 5 3600 | EVGA GTX 1070 FTW2 | 16GB CORSAIR VENGEANCE LPX 3200 DDR4 | MSI B350M MORTAR | 250GB SAMSUNG EVO 860 | 4TB TOSHIBA X 300 | 1TB TOSHIBA SSHD | 120GB KINGSTON SSD | WINDOWS 10 PRO | INWIN 301| BEQUIET PURE POWER 10 500W 80+ SILVER | ASUS 279H | LOGITECH Z906 | DELL KB216T | LOGITECH M185 | SONY DUALSHOCK 4
LENOVO IDEAPAD 510 | i5 7200U | 8GB DDR4 | NVIDIA GEFORCE 940MX | 1TB WD | WINDOWS 10 GO HOME
although in case is it doesn't work do you have a desktop model that I could buy from newegg?
ok
I was originally planing to switch to Linux, or try windows 10
but both ideas I realized probably wouldn't work, so I didn't know what to do.
I think windows 8 is even more demanding than windows 10
Reminder⚠️
Not worth putting any money into. Sorry, time for a new computer.
Quote me to see my reply!
SPECS:
CPU: Xeon X5650 OC'd to 4.2GHz @ 1.35V (courtesy of @XR6)Motherboard: Asus Sabertooth X58 RAM: 4x4GB G.Skill DDR3 1866MHz GPU: Asus RX 570 Strix Storage: WD Blue 1TB and a 128GB Kingston UV400 PSU: EVGA 600B Case: Fractal Design Define C Cooling: H100i V2, be quiet! Pure Wings 2 (two intake, two exhausting through radiator) Monitor: 3x Dell P2210 on a Steelcase Eyesite triple monitor stand Mouse: Logitech G403 Prodigy Wireless Keyboard: It changes, but usually Focus FK-9000 Mousepad: Steelseries QcK XL Headphones:  Sennheiser HD598SE
i use arch btw
