HELP! USB has less capacity than stated
Solved by Master Disaster,
Seller is correct. 232GB for a 256GB drive is about right. The bigger the drive capacity the more space you lose.
FYI it has nothing to do with the drive reserving space. It is because there are actually 2 ways of defining space on a hdd.
https://tierradatarecovery.co.uk/why-does-my-1tb-hard-drive-offer-only-931gb-of-space
Carroma ·
Posted in New Builds and Planning1 -
kasdashd ·
Posted in Folding@home, Boinc, and Coin Mining2 -
K2924 ·
Posted in General Discussion1 -
4
2
hanouzz ·
Posted in Console Gaming3 -
6
4
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
