3 Power supplies or 1?
In a multi-PSU setup, the supplementary PSU are typically put in a severe crossload scenario (high 12V load and no load on the minor rails), where the voltage regulation can behave erractically. Because of that, you simply don't want to grab multiples of random 500w PSUs. You want to look for a power supply that's independently regulated via dual mag amp or uses DC-DC for the minor rails, which a lot of your budget options starts at the ~$60 price point.
Anyways, you could simply buy a modular supply, whose modular board made the 6+2 pin PEG connector and 4+4 CPU connector interchangeable and buy another set of cables separately.
For example, the Corsair RM850x:
If you look at the modular ports, you can potentially put five PEG connectors, five CPU connectors, or a mixed of both. The RM850x has two already.
