WHEEL BEARING GREASE WORKS AS THERMAL PASTE!!!
qonqy_fookat
So I obtained a laptop that had a really bad thermal issue; upon hitting the CPU with a stress test the temperature would INSTANTLY jump to 100C, trigger the PROCHOT, then INSTANTLY drop to like 60C or so, and repeat. I think what happened was someone took the heatsink off and put it back on but didn't change the dried out factory thermal paste, so since it was dried out it probably left lots of tiny gaps. (3/5 of the screws being loose probably didn't help either.) I need to buy some good new thermal paste but in the meantime I decided to try a temporary alternative so I tried some blue wheel bearing grease I had (melting point over 200C so no worries there) and to my surprise it WORKED! Temps still fluctuate kinda fast but when I start the stress test, it gets to 80 pretty quick but then holds there and slowly rises from there up to the 90s as the heatsink heats up. It appears it can just about keep the CPU running at full load and max turbo frequency at 90C without throttling.
So yeah it's not as good as good thermal paste but it does work and is WAY better than nothing!
Who Tf Asked Nasas Radar Dish GIF - WhoTfAsked NasasRadarDish WhoAsked GIFs
Thermal paste is like $5-15 for a tube that will last dozens of repastes...
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
to be honest.. depending on the heatsink and just how smooth the surfaces are.. that may be closer to dry temperatures than to paste temperatures.
also, there's more to "it works" than a temperature difference, most somewhat fluid substances that dont have big grains will have some temperature advantage over going dry.
without having personally tested either, i'd dare say that the only reason wheel bearing grease wins from mayonnaise is that it wont rot away from the heat of your cpu.
  • 3 months later...
On 10/2/2020 at 5:16 PM, kelvinhall05 said:
  Reveal hidden contents
yah but u have to wait for it to ship, i said it was temporary 😠
It turned green after I was done
