Overkill PSU for low noise under load
Solved by The_russian,
I was in almost the same exact situation, I had an old Corsair TX750 and man that thing was loud. I ended up replacing it with a 1000W EVGA psu for the reason you mentioned, I have not heard my psu since. If you want a silent system that’s the way I would go.
asususr ·
Posted in General Discussion1 -
specsdude99 ·
2
2
8
1
Tydn12 ·
Posted in New Builds and Planning5 -
2
ID0 ·
Posted in Networking3 -
eviohh ·
Posted in Troubleshooting4
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
