Search In
  • More options...
Find results that contain...
Find results in...
[closed] We're looking for volunteers to help build and maintain the forum
Go to solution Solved by colonel_mortis,
The people who will take on the new role have now been selected, and know who they are.
My time constraints have meant that a lot of ideas and suggestions end up getting dropped just because I just don't have the time for it. To help address that, we are now looking for people who are willing to put a bit of time towards operating the forum, in an unpaid role. Ideally, I will take on 2-3 people.
You can read a bit more about the tech stack that we use for the forum in this blog post.
Positions
There are a few broad categories of work that we're looking for. These aren't strict categories - if you're interested in all of them, that's great, and if you think you can offer something genuinely useful but which doesn't fit into any of these categories then that may also be ok.
Design and front end development
HTML+CSS
The look of the forum has been largely unchanged since 2016 (although there are some fairly big changes coming soon due to changes to the upstream theme), and it would benefit from some more care and attention from people more design-oriented than me.
The role would involve identifying areas of the forum that don't look great, then designing and implementing changes to the theme to make them better - major restructuring changes are sometimes not feasible due to the theme framework, but there is a wide scope for changes within individual components. It would also involve merging changes from the IPS default theme back into the LTT theme to get the latest bug fixes and enhancements, and testing that everything still works - most of the work here is handled by git, but there are frequently conflicts that need to be resolved manually.
Back end/full stack development
PHP, optionally with a small amount of HTML, CSS and Javascript
There are lots of features that people have suggested over the years, and some of them are even good ideas.
The role would involve building everything from small enhancements (such as showing the subforum in the recent topics list) to large new functionality (such as the upcoming rewrite of status updates from the ground up), and maintaining them against the moving target of the forum software. It also involves debugging issues, both in your own code and in others (the best way to get IPS to fix a gnarly bug is to give them the root cause), and making sure that you don't introduce any security vulnerabilities.
Server administration
CentOS
The server is surprisingly hands-off for serving over 100k unique visitors per day, but I'm no sysadmin so I'm sure there's a bunch of things that are set up in totally wrong ways.
The role here involves generally just be keeping the server running and secure, and you can make of it whatever you want. So far, I've done about the bare minimum needed to get things running, so there's plenty of scope for automation and scripting, as well as containerization, virtualization, or whatever takes your fancy (but remember that that the forum is just running on one server, so if you break it, you will also have to fix it). If you just want to keep things ticking over as they are, that's cool too. Elsaticsearch has caused us a reasonable amount of pain over the last few years, so if you know how to tame it then I want to hear from you.
DevOps
Mixture of technologies
Automate all the things! The Invision Community framework was not designed for testing, and makes tests quite difficult, so my aspiration is that we build a testing framework that overcomes those limitations. This would also cover things like the tools for automatically updating the repo when a new Invision Community release is available.
General Requirements
If you're interested in helping out, please make sure you can spend a few hours helping out with the forum in most weeks (on average - being unavailable during school time but having lots of time available during breaks should also be ok). This is a voluntary position, but Invision Community has over 400k lines of code so ramping up will not be quick.
Initially, I will also act as a product manager, helping to gather suggestions and guide the path forwards. However, over time I intend that everyone is willing to come up with their own ideas for things to change, and to interact with the community on suggestions and feedback.
You will need to work self-guided - time zones and availability will mean that there will often not be anyone around who can answer questions or tell you what to do next. Communication will be through Slack.
Who we're aiming for
We're not looking for people who have no programming experience, or who are just starting out with programming. I encourage you to keep going with it, but helping out with the forum will not be the right environment for learning the basics.
However, we are open to people who have worked on a few decently sized personal projects and understand the importance of structured, maintainable code, and are looking to work on something a bit more real-world. For these people, I hope that working on the forum can present an opportunity to grow and learn a lot more about Software Engineering, but in return they must be willing and able to learn quickly.
We are also open to people who have more experience to bring to the table, for whom the forum might be a side project or a way to try out some different technologies.
This isn't an opportunity to get rich, but it is a way of giving back to the community, building your skills, and getting a reference for jobs/university/etc.
FAQs
Why do you use PHP? PHP sucks, x is much better. Yes, PHP is a very bad language, but we are constrained by the forum software that we're using. If I rewrote everything from scratch tomorrow, I would probably use Go, but I would also be here a very long time.
I don't know PHP, can I still help? If you have a reasonable amount of experience with other languages, PHP shouldn't be too hard to pick up. The code is fairly similar to Java, although without types.
Why don't you just open source everything, so everyone can contribute? The forum software is proprietary, and owned by IPS, so we can't open source that. Without the forum software itself, there's not much use in open sourcing the rest, and doing so would come with its own set of problems. Also, due to the size of the codebase, it would be better to have a few people who have ownership and understand the code, rather than a bunch of contributors who only understand it superficially.
Why only have a small number of people? What one developer can do in one week, two developers can do in two weeks. Having lots of people would mean that I have to spend even more time trying to organise things (and less time keeping the forum going or directly helping people to ramp up), at least at the beginning, and that won't end up being a good experience for anyone. Also, giving 30 people access to the forum software would almost certainly breach our license agreement.
Will I be a moderator? No, although it isn't mutually exclusive with being a moderator.
Will I get to interact with LMG much? No. LMG are very hands-off with the forum, so you should assume that there will be virtually no interaction.
Does this let me work on Floatplane too? No.
I don't use the forum, can I still apply? Being an existing forum user is not an absolute requirement, but it is definitely quite beneficial - it's hard to find things to improve if you're not already using it. If you got the role, you would be required to at least use the meta sections of the forum (Bugs and Issues & Forum Suggestions).
When will I hear back? It depends how many people apply, but I anticipate that it will take several weeks. We aim to email everyone with a decision once it has been made.
Can I put this on my resume? Yes.
If I do this, will I get a forum badge? Yes.
Will there be meetings to attend or paperwork to fill in? You will have to agree not to share the forum's code, but otherwise there won't be paperwork. Depending on what people want and how availability works out, we might have a biweekly or monthly meeting to keep everyone in sync on what's being worked on, but that is not decided yet; most communication will be in Slack, although especially towards the beginning there will be more voice/video calls to get ramped up.
Will I get woken up in the middle of the night when things break? No, unless you want to. The forum is generally pretty stable, and most outages are either load related or out of our control, so we're not likely to need any specific person to investigate.
Will there be deadlines to meet? No, any changes will only be released when they're ready, with no pressure to get it done for a specific date (although sometimes it can be helpful to set yourself a target).
How will I test my changes? Everyone will install a local version of the forum software on their machine (Windows, MacOS and Linux should all work), so they can make and test changes easily. No testing in prod please!
Are there any conflict of interest rules? As long as you're doing things for the benefit of the forum/community rather than for anyone else, and you're not being paid by anyone else for your time, there shouldn't be any issues. If you have questions or concerns, please reach out to me by PM.
What's the privacy policy for the data that I submit in the application process? Unless otherwise noted, all data submitted in the application process will be available only to the forum admin team and Linus Media Group, and will only be used in connection with the hiring process. Your information will not be shared with third parties, and it will be deleted once the hiring process has finished.
I have a question that isn't answered here. Post questions in this topic (preferred), or send me a PM. Note that this will probably make me quite busy, so it might take me some time to get to your question.
Apply
Applications are now closed
Quote
If you know how to tame Elasticsearch, I want to hear from you.
Okay you got me to apply
Just keeping this here as a backup 9̵̨̢̨̧̧̡̧̡̧̡̧̡̡̢̢̡̢̧̡̢̡̡̢̧̛̛̛̛̛̛̱̖͈̠̝̯̹͉̝̞̩̠̹̺̰̺̲̳͈̞̻̜̫̹̱̗̣͙̻̘͎̲̝͙͍͔̯̲̟̞͚̖̘͉̭̰̣͎͕̼̼̜̼͕͎̣͇͓͓͎̼̺̯͈̤̝͖̩̭͍̣̱̞̬̺̯̼̤̲͎̖̠̟͍̘̭͔̟̗̙̗̗̤̦͍̫̬͔̦̳̗̳͔̞̼̝͍̝͈̻͇̭̠͈̳͍̫̮̥̭͍͔͈̠̹̼̬̰͈̤͚̖̯͍͉͖̥̹̺͕̲̥̤̺̹̹̪̺̺̭͕͓̟̳̹͍̖͎̣̫͓͍͈͕̳̹̙̰͉͙̝̜̠̥̝̲̮̬͕̰̹̳͕̰̲̣̯̫̮͙̹̮͙̮̝̣͇̺̺͇̺̺͈̳̜̣̙̻̣̜̻̦͚̹̩͓͚̖͍̥̟͍͎̦͙̫̜͔̭̥͈̬̝̺̩͙͙͉̻̰̬̗̣͖̦͎̥̜̬̹͓͈͙̤̜̗͔̩̖̳̫̑̀̂̽̈́̈́̿͒̿̋̊͌̾̄̄̒̌͐̽̿̊͑̑̆͗̈̎̄͒̑̋͛̑͑̂͑̀͐̀͑̓͊̇͆̿͑͛͛͆́͆̓̿̇̀̓͑͆͂̓̾̏͊̀̇̍̃́̒̎̀̒̄̓̒̐̑̊̏̌̽̓͂͋̓̐̓͊̌͋̀̐̇̌̓̔͊̈̇́̏͒̋͊̓̆̋̈̀̌̔͆͑̈̐̈̍̀̉̋̈́͊̽͂̿͌͊̆̾̉͐̿̓̄̾͑̈́͗͗̂̂́̇͂̀̈́́̽̈́̓̓͂̽̓̀̄͌̐̔̄̄͒͌̈́̅̉͊̂͒̀̈́̌͂̽̀̑̏̽̀͑̐̐͋̀̀͋̓̅͋͗̍́͗̈́̆̏̇͊̌̏̔̑̐̈́͑̎͑͆̏̎́̑̍̏̒̌̊͘͘̚̕̚̕̕̚̕̚̕̕͜͜͜͜͜͝͝͠͠͝͝͝͝͝͝͝͠͝͝ͅͅͅͅͅͅͅ8̵̨̛̛̛̛̮͍͕̥͉̦̥̱̞̜̫̘̤̖̬͍͇͓̜̻̪̤̣̣̹̑͑̏̈́̐̐́̎͒̔͒̌̑̓̆̓͑̉̈́́͋̌͋͐͛͋̃̍̽̊͗͋͊̂̅͊͑́͋͛̉̏̓͌̾̈́̀͛͊̾͑̌̀̀̌̓̏̑́̄̉̌͂́͛̋͊̄͐͊̈́̀̌̆̎̿̓̔̍̎̀̍̚̕̕͘͘͘̕̚͝͝͠͠͠0̶̡̡̡̢̨̨͕̠̠͉̺̻̯̱̘͇̥͎͖̯͕̖̬̭͔̪̪͎̺̠̤̬̬̤̣̭̣͍̥̱̘̳̣̤͚̭̥͚̦͙̱̦͕̼͖͙͕͇̭͓͉͎̹̣̣͕̜͍͖̳̭͕̼̳̖̩͍͔̱̙̠̝̺̰̦̱̿̄̀͐͜͜ͅͅt̶̡̨̡̨̧̢̧̢̨̧̧̧̧̢̡̨̨̢̨̢̧̢̛̛̛̛̛̠͍̞̮͇̪͉̩̗̗͖̫͉͎͓̮̣̘̫͔̘̬̮̙̯̣͕͓̲̣͓͓̣̹̟͈̱͚̘̼̙̖̖̼̙̜̝͙̣̠̪̲̞̖̠̯̖̠̜̱͉̲̺͙̤̻̦̜͎̙̳̺̭̪̱͓̦̹̺͙̫̖̖̰̣͈͍̜̺̘͕̬̥͇̗̖̺̣̲̫̟̣̜̭̟̱̳̳̖͖͇̹̯̜̹͙̻̥̙͉͕̜͎͕̦͕̱͖͉̜̹̱̦͔͎̲̦͔̖̘̫̻̹̮̗̮̜̰͇̰͔̱͙̞̠͍͉͕̳͍̰̠̗̠̯̜̩͓̭̺̦̲̲͖̯̩̲̣̠͉̦̬͓̠̜̲͍̘͇̳̳͔̼̣͚̙͙͚͕̙̘̣̠͍̟̪̝̲͇͚̦̖͕̰̟̪͖̳̲͉͙̰̭̼̩̟̝̣̝̬̳͎̙̱͒̃̈͊̔͒͗̐̄̌͐͆̍͂̃̈́̾͗̅̐͒̓̆͛̂̾͋̍͂̂̄̇̿̈͌̅̈́̃̾̔̇̇̾̀͊͋̋̌̄͌͆͆̎̓̈́̾̊͊̇̌̔̈́̈́̀̐͊̊̍͑̊̈̓͑̀́̅̀̑̈́̽̃̽͛̇́̐̓̀͆̔̈̀̍̏̆̓̆͒̋́̋̍́̂̉͛̓̓̂̋̎́̒̏̈͋̃̽͆̓̀̔͑̈́̓͌͑̅̽́̐̍̉̑̓̈́͌̋̈́͂̊́͆͂̇̈́̔̃͌̅̈́͌͛̑̐̓̔̈́̀͊͛̐̾͐̔̾̈̃̈̄͑̓̋̇̉̉̚̕̚͘̕̚̚̕̕͜͜͜͜͜͜͜͜͜͜͜͜͜͝͝͝͠͝͝͝͝͝͠ͅͅͅͅͅi̵̢̧̢̧̡̧̢̢̧̢̢̢̡̡̡̧̧̡̡̧̛̛͈̺̲̫͕̞͓̥̖̭̜̫͉̻̗̭̖͔̮̠͇̩̹̱͈̗̭͈̤̠̮͙͇̲͙̰̳̹̲͙̜̟͚͎͓̦̫͚̻̟̰̣̲̺̦̫͓̖̯̝̬͉̯͓͈̫̭̜̱̞̹̪͔̤̜͙͓̗̗̻̟͎͇̺̘̯̲̝̫͚̰̹̫̗̳̣͙̮̱̲͕̺̠͉̫̖̟͖̦͉̟͈̭̣̹̱̖̗̺̘̦̠̯̲͔̘̱̣͙̩̻̰̠͓͙̰̺̠̖̟̗̖͉̞̣̥̝̤̫̫̜͕̻͉̺͚̣̝̥͇̭͎̖̦̙̲͈̲̠̹̼͎͕̩͓̖̥̘̱̜͙̹̝͔̭̣̮̗̞̩̣̬̯̜̻̯̩̮̩̹̻̯̬̖͂̈͂̒̇͗͑̐̌̎̑̽̑̈̈́͑̽́̊͋̿͊͋̅̐̈́͑̇̿̈́̌͌̊̅͂̎͆̏̓͂̈̿̏̃͑̏̓͆̔̋̎̕͘͘͘͜͜͜͜͜͜͜͝͝͠͠ͅͅͅͅͅͅͅͅͅZ̴̧̢̨̢̧̢̢̡̧̢̢̢̨̨̨̡̨̧̢̧̛̛̬̖͈̮̝̭̖͖̗̹̣̼̼̘̘̫̠̭̞͙͔͙̜̠̗̪̠̼̫̻͓̳̟̲̳̻̙̼͇̺͎̘̹̼͔̺̹̬̯̤̮̟͈̭̻͚̣̲͔͙̥͕̣̻̰͈̼̱̺̤̤͉̙̦̩̗͎̞͓̭̞̗͉̳̭̭̺̹̹̮͕̘̪̞̱̥͈̹̳͇̟̹̱̙͚̯̮̳̤͍̪̞̦̳̦͍̲̥̳͇̪̬̰̠͙͕̖̝̫̩̯̱̘͓͎̪͈̤̜͎̱̹̹̱̲̻͎̖̳͚̭̪̦̗̬͍̯̘̣̩̬͖̝̹̣̗̭͖̜͕̼̼̲̭͕͔̩͓̞̝͓͍̗̙̯͔̯̞̝̳̜̜͉̖̩͇̩̘̪̥̱͓̭͎͖̱̙̩̜͎̙͉̟͎͔̝̥͕͍͓̹̮̦̫͚̠̯͓̱͖͔͓̤͉̠͙̋͐̀͌̈́͆̾͆̑̔͂͒̀̊̀͋͑̂͊̅͐̿́̈́̐̀̏̋̃̄͆͒̈́̿̎́́̈̀̀͌̔͋͊̊̉̿͗͊͑̔͐̇͆͛̂̐͊̉̄̈́̄̐͂͂͒͑͗̓͑̓̾̑͋̒͐͑̾͂̎̋̃̽̂̅̇̿̍̈́́̄̍͂͑̏̐̾̎̆̉̾͂̽̈̆̔́͋͗̓̑̕͘̕͘͜͜͜͜͜͝͝͝͝͠͠͝ͅo̶̪͆́̀͂̂́̄̅͂̿͛̈́̿͊͗́͘͝t̴̡̨̧̨̧̡̧̨̡̢̧̢̡̨̛̪͈̣̭̺̱̪̹̺̣̬̖̣̻͈̞̙͇̩̻̫͈̝̭̟͎̻̟̻̝̱͔̝̼͍̞̼̣̘̤̯͓͉̖̠̤͔̜̙͚͓̻͓̬͓̻̜̯̱̖̳̱̗̠̝̥̩͓̗̪̙͓̖̠͎̗͎̱̮̯̮͙̩̫̹̹̖͙̙͖̻͈̙̻͇͔̙̣̱͔̜̣̭̱͈͕̠̹͙̹͇̻̼͎͍̥̘͙̘̤̜͎̟͖̹̦̺̤͍̣̼̻̱̲͎̗̹͉͙̪̞̻̹͚̰̻͈͈͊̈́̽̀̎̃̊́̈́̏̃̍̉̇̑̂̇̏̀͊̑̓͛̽͋̈́͆́̊͊̍͌̈́̓͊̌̿̂̾̐͑̓̀́͒̃̋̓͆̇̀͊̆͗̂͑͐̀͗̅̆͘̕͘̕̕͜͜͝͝͝͝͝͝͝ͅͅͅͅͅͅͅͅͅḁ̶̢̡̨̧̡̡̨̨̧̨̡̡̢̧̨̡̡̛̛̛͍̱̳͚͕̩͍̺̪̻̫̙͈̬͙̖͙̬͍̬̟̣̝̲̼̜̼̺͎̥̮̝͙̪̘̙̻͖͇͚͙̣̬̖̲̲̥̯̦̗̰̙̗̪̞̗̩̻̪̤̣̜̳̩̦̻͓̞̙͍͙̫̩̹̥͚̻̦̗̰̲̙̫̬̱̺̞̟̻͓̞͚̦̘̝̤͎̤̜̜̥̗̱͈̣̻̰̮̼̙͚͚̠͚̲̤͔̰̭̙̳͍̭͎̙͚͍̟̺͎̝͓̹̰̟͈͈̖̺͙̩̯͔̙̭̟̞̟̼̮̦̜̳͕̞̼͈̜͍̮͕̜͚̝̦̞̥̜̥̗̠̦͇͖̳͈̜̮̣͚̲̟͙̎̈́́͊̔̑̽̅͐͐͆̀͐́̓̅̈͑͑̍̿̏́͆͌̋̌̃̒̽̀̋̀̃̏̌́͂̿̃̎̐͊̒̀̊̅͒̎͆̿̈́̑̐̒̀̈́̓̾͋͆̇̋͒̎̈̄̓̂͊̆͂̈́̒̎͐̇̍̆̋̅̿̔͒̄̇̂̋̈́͆̎̔̇͊̊̈́̔̏͋́̀͂̈́̊͋͂̍̾̓͛̇̔̚͘̚̕̚͘͘̕̕̕̚͘͘̚̕̚̕͜͜͜͝͝͝͝͝͝͝͝ͅͅͅͅͅç̵̧̢̨̢̢̢̧̧̡̨̡̢̧̧̧̨̡̡̨̨̢̢̢̧̨̢̨̢̛̛͉̗̠͇̹̖̝͕͚͎̟̻͓̳̰̻̺̞̣͚̤͙͍͇̗̼͖͔͕͙͖̺͙̖̹̘̘̺͓̜͍̣̰̗̖̺̗̪̘̯̘͚̲͚̲̬̞̹̹͕̭͔̳̘̝̬͉̗̪͉͕̞̫͔̭̭̜͉͔̬̫͙̖̙͚͔͙͚͍̲̘͚̪̗̞̣̞̲͎͔͖̺͍͎̝͎͍̣͍̩̟͈͕̗͉̪̯͉͎͖͍̖͎̖̯̲̘̦̟̭͍͚͓͈͙̬͖̘̱̝̜̘̹̩̝̥̜͎̬͓̬͙͍͇͚̟̫͇̬̲̥̘̞̘̟̘̝̫͈̙̻͇͎̣̪̪̠̲͓͉͙͚̭̪͇̯̠̯̠͖̞̜͓̲͎͇̼̱̦͍͉͈͕͉̗̟̖̗̱̭͚͎̘͓̬͍̱͍̖̯̜̗̹̰̲̩̪͍̞̜̫̩̠͔̻̫͍͇͕̰̰̘͚͈̠̻̮͊̐̿̏̐̀̇̑̐̈͛͑͑̍̑̔̃̈́̓̈́̇̐͑̐̊̆͂̀̏͛̊̔̍̽͗͋̊̍̓̈́̏̅͌̀̽́̑͒͒̓͗̈́̎͌͂̕̚͘͘͜͜͜͜͜͠͝͝͝͝ͅͅͅͅͅͅͅS̵̡̡̧̧̨̨̡̢̡̡̡̡̧̧̡̧̢̫̯͔̼̲͉͙̱̮̭̗͖̯̤͙̜͚̰̮̝͚̥̜̞̠̤̺̝͇̻̱͙̩̲̺͍̳̤̺̖̝̳̪̻̗̮̪̖̺̹̭͍͇̗̝̱̻̳̝̖̝͎̙͉̞̱̯̙̜͇̯̻̞̱̭̗͉̰̮̞͍̫̺͙͎̙̞̯̟͓͉̹̲͖͎̼̫̩̱͇̲͓̪͉̺̞̻͎̤̥̭̺̘̻̥͇̤̖̰̘̭̳̫̙̤̻͇̪̦̭̱͎̥̟͖͕̣̤̩̟̲̭̹̦̹̣͖̖͒̈́̈́̓͗̈̄͂̈́̅̐̐̿̎̂͗̎̿̕͘͜͜͜͜͝͝ͅͅt̸̡̡̧̧̨̡̢̛̥̥̭͍̗͈̩͕͔͔̞̟͍̭͇̙̺̤͚͎͈͎͕̱͈̦͍͔͓̬͚̗̰̦͓̭̰̭̎̀̂̈́̓̒̈́̈́̂̄̋́̇̂͐͒̋̋̉͐̉̏̇͋̓̈́͐̾͋̒͒͐̊̊̀̄͆̄͆̑͆̇̊̓̚̚̕̚̕͜͠͝͝ͅͅơ̵̡̨̡̡̡̨̛̺͕̼͔̼̪̳͖͓̠̘̘̳̼͚͙͙͚̰͚͚͖̥̦̥̘̖̜̰͔̠͕̦͎̞̮͚͕͍̤̠̦͍̥̝̰̖̳̫̮̪͇̤̱̜͙͔̯͙̙̼͇̹̥̜͈̲̺̝̻̮̬̼̫̞̗̣̪̱͓̺̜̠͇͚͓̳̹̥̳̠͍̫͈̟͈̘̯̬̞͔̝͍͍̥̒̐͗͒͂͆̑̀̿̏́̀͑͗̐́̀̾̓́̌̇̒̈́̌̓͐̃̈́̒̂̀̾͂̊̀̂͐̃̄̓̔̽̒̈́̇̓͌̇̂̆̒̏̊̋͊͛͌̊̇̒̅͌̄̎̔̈́͊́̽̋̈̇̈́́͊̅͂̎̃͌͊͛͂̄̽̈́̿͐̉̽̿́́̉͆̈́̒́̂̾̄̇̌̒̈̅̍̿̐͑̓͊̈́̈̋̈́̉̍̋̊̈̀̈́̾̿̌̀̈́͌̑̍́̋̒̀̂̈́́̾̏̐̅̈̑͗͐̈͂̄̾̄̈́̍̉͑͛͗͋̈́̃̄̊́́͐̀̀̽̇̓̄̓̃͋͋̂̽̔̀̎͌̈́̈́̑̓̔̀̓͐͛͆̿̋͑͛̈́͂̅̋̅͆͗̇́̀̒́̏͒̐̍͂̓͐͐̇̂̉̑̊͑̉̋̍͊̄̀͂̎͒̔͊̃̏̕̚̕̕͘͘͘̚͘̚͘̕͘̚͘̚̚̚̕͘͜͜͜͝͝͠͠͝͝͠͠͝͝͝͝͝͝͝͝͝ͅͅͅc̴̨̡̢̢̢̡̡̢̛̛̛̻͇̝̣͉͚͎͕̻̦͖̤̖͇̪̩̤̻̭̮̙̰̖̰̳̪̱̹̳̬͖̣͙̼̙̰̻̘͇͚̺̗̩̫̞̳̼̤͔͍͉̟͕̯̺͈̤̰̹̍̋́͆̾̆̊͆͋̀͑͒̄̿̄̀̂͋̊͆́͑̑̽͊̓́̔̽̌͊̄͑͒͐̑͗̿̃̀̓̅́̿͗̈́͌̋̀̏̂͌̓́̇̀͒͋̌̌̅͋͌̆͐̀̔̒͐̊̇̿̽̀̈́̃̒̋̀̈́̃̏̂̊͗̑̊̈̇̀̌͐̈́̉̂̏͊̄͐̈̽͒̏̒̓́̌̓̅́̓̃͐͊͒̄͑̒͌̍̈́̕͘̚͘̕͘̚̕͜͝͠͝͝͝ͅǩ̴̢̢̢̧̨̢̢̢̨̨̨̢̢̢̨̧̨̡̡̢̛̛̛̛̛̛̛̜̥̩̙͕̮̪̻͈̘̯̼̰̜͚̰͖̬̳͖̣̭̼͔̲͉̭̺͚̺̟͉̝̱̲͎͉̙̥̤͚͙̬̪̜̺͙͍̱̞̭̬̩̖̤̹̤̺̦͈̰̗̰͍͇̱̤̬̬͙̙̲̙̜͖͓̙̟̙̯̪͍̺̥͔͕̝̳̹̻͇̠̣͈̰̦͓͕̩͇͈͇̖͙͍̰̲̤̞͎̟̝̝͈͖͔͖̦̮̗̬̞̞̜̬̠̹̣̣̲̮̞̤̜̤̲̙͔͕̯͔͍̤͕̣͔͙̪̫̝̣̰̬̬̭̞͔̦̟̥̣̻͉͈̮̥̦̮̦͕̤͇̺͆͆̈͗̄̀̌̔̈́̈̉̾̊̐̆̂͛̀̋́̏̀̿͒̓̈́̈́͂̽̾͗͊̋̐̓̓̀̃̊̊͑̓̈̎̇͑̆̂̉̾̾̑͊̉̃́̑͌̀̌̐̅̃̿̆̎̈́̀̒́͛̓̀̊́̋͛͒͊̆̀̃̊͋̋̾̇̒̋͂̏͗͆̂̔́̐̀́͗̅̈̋̂̎̒͊̌̉̈̈́͌̈́̔̾̊̎́͐͒̋̽̽́̾̿̚̕͘͘̚̕̕̕̚̚̕̚̕͘͜͜͜͝͠͝͝͝͝͝͝͝͝ͅͅͅͅͅͅB̸̢̧̨̡̢̧̨̡̡̨̡̨̡̡̡̢̨̢̨̛̛̛̛̛̛͉̞͚̰̭̲͈͎͕͈̦͍͈̮̪̤̻̻͉̫̱͔̞̫̦̰͈̗̯̜̩̪̲̻̖̳͖̦͎͔̮̺̬̬̼̦̠̪̤͙͍͓̜̥̙̖̫̻̜͍̻̙̖̜̹͔̗̪̜̖̼̞̣̠̫͉̯̮̤͈͎̝̪͎͇͙̦̥͙̳̫̰̪̣̱̘̤̭̱͍̦͔̖͎̺̝̰̦̱̣͙̙̤͚̲͔̘̱̜̻͔̥̻͖̭͔̜͉̺͕͙͖̜͉͕̤͚̠̩̮̟͚̗͈͙̟̞̮̬̺̻̞͔̥͉͍̦̤͓̦̻̦̯̟̰̭̝̘̩̖̝͔̳͉̗̖̱̩̩̟͙͙͛̀͐̈́̂̇͛̅̒̉̏̈́̿͐́̏̃̏̓̌̽͐̈́͛̍͗͆͛̋̔̉͂̔̂̓̌͌͋̂͆̉͑̊̎́̈́̈̂͆͑́̃̍̇̿̅̾́́̿̅̾̆̅̈́̈̓͒͌͛̃͆̋͂̏̓̅̀͂̽̂̈̈́̎̾̐͋͑̅̍̈́̑̅̄͆̓̾̈́͐̎̊͐̌̌̓͊̊̔̈́̃͗̓͊͐̌͆̓͗̓̓̾̂̽͊͗́́́̽͊͆͋͊̀̑̿̔͒̏̈́́̏͆̈́͋̒͗͂̄̇̒͐̃͑̅̍͒̎̈́̌̋́̓͂̀̇͛̋͊͆̈́̋́̍̃͒̆̕̚̚̕̕̕͘̕̚̚͘̕͜͜͜͜͝͠͠͝͠͝͝͝͝͠͝͝͝͝ͅͅͅͅͅI̵̡̢̧̨̡̢̨̡̡̢̡̧̡̢̢̢̡̢̛̛͕͎͕̩̠̹̩̺̣̳̱͈̻̮̺̟̘̩̻̫͖̟͓̩̜̙͓͇̙̱̭̰̻̫̥̗̠͍͍͚̞̘̫͉̬̫̖̖̦͖͉̖̩̩̖̤̺̥̻̝͈͎̻͓̟̹͍̲͚͙̹̟̟̯͚̳̟͕̮̻̟͈͇̩̝̼̭̯͚͕̬͇̲̲̯̰̖̙̣̝͇̠̞̙͖͎̮̬̳̥̣̺̰͔̳̳̝̩̤̦̳̞̰̩̫̟͚̱̪̘͕̫̼͉̹̹̟̮̱̤̜͚̝̠̤̖̮̯̳͖̗̹̞̜̹̭̿̏͋̒͆̔̄̃̾̓͛̾̌́̅̂͆̔͌͆͋̔̾́̈̇̐̄̑̓̂̾́̄̿̓̅̆͌̉̎̏̄͛̉͆̓̎͒͘̕̕͜͜͜͜͜͜͜͝͠ͅͅƠ̷̢̛̛̛̛̛̛̛̛̟̰͔͔͇̲̰̮̘̭̭̖̥̟̘̠̬̺̪͇̲͋͂̅̈́̍͂̽͗̾͒̇̇̒͐̍̽͊́̑̇̑̾̉̓̈̾͒̍̌̅̒̾̈́̆͌̌̾̎̽̐̅̏́̈̔͛̀̋̃͊̒̓͗͒̑͒̃͂̌̄̇̑̇͛̆̾͛̒̇̍̒̓̀̈́̄̐͂̍͊͗̎̔͌͛̂̏̉̊̎͗͊͒̂̈̽̊́̔̊̃͑̈́̑̌̋̓̅̔́́͒̄̈́̈̂͐̈̅̈̓͌̓͊́̆͌̉͐̊̉͛̓̏̓̅̈́͂̉̒̇̉̆̀̍̄̇͆͛̏̉̑̃̓͂́͋̃̆̒͋̓͊̄́̓̕̕̕̚͘͘͘̚̕̚͘̕̕͜͜͝͝͝͠͝͝͝͝͠ͅS̷̢̨̧̢̡̨̢̨̢̨̧̧̨̧͚̱̪͇̱̮̪̮̦̝͖̜͙̘̪̘̟̱͇͎̻̪͚̩͍̠̹̮͚̦̝̤͖̙͔͚̙̺̩̥̻͈̺̦͕͈̹̳̖͓̜͚̜̭͉͇͖̟͔͕̹̯̬͍̱̫̮͓̙͇̗̙̼͚̪͇̦̗̜̼̠͈̩̠͉͉̘̱̯̪̟͕̘͖̝͇̼͕̳̻̜͖̜͇̣̠̹̬̗̝͓̖͚̺̫͛̉̅̐̕͘͜͜͜͜ͅͅͅ.̶̨̢̢̨̢̨̢̛̻͙̜̼̮̝̙̣̘̗̪̜̬̳̫̙̮̣̹̥̲̥͇͈̮̟͉̰̮̪̲̗̳̰̫̙͍̦̘̠̗̥̮̹̤̼̼̩͕͉͕͇͙̯̫̩̦̟̦̹͈͔̱̝͈̤͓̻̟̮̱͖̟̹̝͉̰͊̓̏̇͂̅̀̌͑̿͆̿̿͗̽̌̈́̉̂̀̒̊̿͆̃̄͑͆̃̇͒̀͐̍̅̃̍̈́̃̕͘͜͜͝͠͠z̴̢̢̡̧̢̢̧̢̨̡̨̛̛̛̛̛̛̛̛̲͚̠̜̮̠̜̞̤̺͈̘͍̻̫͖̣̥̗̙̳͓͙̫̫͖͍͇̬̲̳̭̘̮̤̬̖̼͎̬̯̼̮͔̭̠͎͓̼̖̟͈͓̦̩̦̳̙̮̗̮̩͙͓̮̰̜͎̺̞̝̪͎̯̜͈͇̪̙͎̩͖̭̟͎̲̩͔͓͈͌́̿͐̍̓͗͑̒̈́̎͂̋͂̀͂̑͂͊͆̍͛̄̃͌͗̌́̈̊́́̅͗̉͛͌͋̂̋̇̅̔̇͊͑͆̐̇͊͋̄̈́͆̍̋̏͑̓̈́̏̀͒̂̔̄̅̇̌̀̈́̿̽̋͐̾̆͆͆̈̌̿̈́̎͌̊̓̒͐̾̇̈́̍͛̅͌̽́̏͆̉́̉̓̅́͂͛̄̆͌̈́̇͐̒̿̾͌͊͗̀͑̃̊̓̈̈́̊͒̒̏̿́͑̄̑͋̀̽̀̔̀̎̄͑̌̔́̉̐͛̓̐̅́̒̎̈͆̀̍̾̀͂̄̈́̈́̈́̑̏̈́̐̽̐́̏̂̐̔̓̉̈́͂̕̚̕͘͘̚͘̚̕̚̚̚͘̕̕̕͜͜͝͠͠͝͝͝͝͠͝͝͝͠͝͝͝͝͝͝ͅͅͅī̸̧̧̧̡̨̨̢̨̛̛̘͓̼̰̰̮̗̰͚̙̥̣͍̦̺͈̣̻͇̱͔̰͈͓͖͈̻̲̫̪̲͈̜̲̬̖̻̰̦̰͙̤̘̝̦̟͈̭̱̮̠͍̖̲͉̫͔͖͔͈̻̖̝͎̖͕͔̣͈̤̗̱̀̅̃̈́͌̿̏͋̊̇̂̀̀̒̉̄̈́͋͌̽́̈́̓̑̈̀̍͗͜͜͠͠ͅp̴̢̢̧̨̡̡̨̢̨̢̢̢̨̡̛̛͕̩͕̟̫̝͈̖̟̣̲̖̭̙͇̟̗͖͎̹͇̘̰̗̝̹̤̺͉͎̙̝̟͙͚̦͚͖̜̫̰͖̼̤̥̤̹̖͉͚̺̥̮̮̫͖͍̼̰̭̤̲͔̩̯̣͖̻͇̞̳̬͉̣̖̥̣͓̤͔̪̙͎̰̬͚̣̭̞̬͎̼͉͓̮͙͕̗̦̞̥̮̘̻͎̭̼͚͎͈͇̥̗͖̫̮̤̦͙̭͎̝͖̣̰̱̩͎̩͎̘͇̟̠̱̬͈̗͍̦̘̱̰̤̱̘̫̫̮̥͕͉̥̜̯͖̖͍̮̼̲͓̤̮͈̤͓̭̝̟̲̲̳̟̠͉̙̻͕͙̞͔̖͈̱̞͓͔̬̮͎̙̭͎̩̟̖͚̆͐̅͆̿͐̄̓̀̇̂̊̃̂̄̊̀͐̍̌̅͌̆͊̆̓́̄́̃̆͗͊́̓̀͑͐̐̇͐̍́̓̈́̓̑̈̈́̽͂́̑͒͐͋̊͊̇̇̆̑̃̈́̎͛̎̓͊͛̐̾́̀͌̐̈́͛̃̂̈̿̽̇̋̍͒̍͗̈͘̚̚͘̚͘͘͜͜͜͜͜͜͠͠͝͝ͅͅͅ☻♥■∞{╚mYÄÜXτ╕○\╚Θº£¥ΘBM@Q05♠{{↨↨▬§¶‼↕◄►☼1♦  wumbo╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ╚̯̪̣͕̙̩̦͓͚̙̱̘̝̏̆ͤ̊̅ͩ̓̏̿͆̌Θ̼̯͉ͭͦ̃͊͑̉ͯͤ̈́ͬ͐̈́͊ͤͅº͍̪͇͖̝̣̪̙̫̞̦̥ͨ̂ͧ̄̿£̺̻̹̠̯͙͇̳ͬ̃̿͑͊ͨͣ
I've been looking forward to this! Continuing to build my personal site in the background. Hope I can help bring some of these good ideas to life in the near future!
Thanks for the consideration!
I applied.
HMU with any questions.
I'm open to learning about different positions, but I'd prefer the ones I applied for. Definitely where I'd excel the most.
Don’t take any of my posts seriously.
LTT Fan Fiction:
PC game list:
Why is LMG, a for-profit company, asking people to work for them for free? Are they in such financial distress that they can't afford to give their worker's even a minimum wage?
MacBook Pro 16
i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME - many dongles
Just now, Energycore said:
The forum does not give LMG any profit at all.
The small number of ads barely cover the server costs. If you don't feel like giving back, you don't have to :)
Doesn't matter if they specifically make any money from the forum. Support forums for other companies aren't profitable, but HP, Bose and whoever else absolutely pay their forum developer/support employees. LMG should be no exception.
MacBook Pro 16
It's common that corporations & companies don't pay moderators & similar remote workers.
These are low barrier to entry jobs & are more of a serious hobby & model community members.
Some companies do give gifts to model community members/moderators, but it's probably never been straight money. Usually an exclusive T-Shirt, mouse pads, coffee mugs & other "Thank you for volunteering your time to us."
Positions like this are typically entry points to companies, so it's like a long term job application.
I doubt anyone working as an admin for LTT forum will work at LTT as programmers are not needed for their major work/income. However, other companies do sometimes take the fact that you worked on their community as serious incentive to hire them. It's also a great portfolio piece. LTT could easily contract this work out to a company, but people like me see it as a great portfolio piece that'd shine on their portfolio setting them up for positions at companies.
If one gets accepted to work on this forum, & keep at it for 6 months to a year (minimum) then LMG will have gotten them a free job launching their career by giving them hands on experience with a real system. Scarcely any other college graduates will have something as bright as "I worked on the #1 computer YouTube channel's official forum using X, Y, Z technologies. I have job experience & am not some inexperienced college graduate."
Because of this, anyone that works on this forum for their portfolio might not start out as entry level. They may start their first job at intermediate level pay. Really, this is a wonderful opportunity for anyone looking to get into web technologies & networking/database related fields.
LTT Fan Fiction:
PC game list:
LMG is rather hands off when it comes to the forum. The day to day operations are run completely by volunteers such as Mortis and your helpful mods since...well since the Forum began. It's a completely community driven community which is what makes it so great and not corporate like the forums you've mentioned.
AMD FX™ 6300 @ 4.20 GHz | ASUS M5A97 R2.0 | MSI GTX 550Ti | 16GB Kingston DDR3 | Samsung 850 EVO 250GB WD 750GB | Antec 300 | ASUS Xonar DG | CoolerMaster Hyper 212 Evo | OCZ 600W | Windows 10 Pro
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5
Intel Core™ i7-7600U | Seagate 500GB HDD | 16GB DDR4 | Windows 10 Enterprise | HP EliteBook 850 G4
Intel Core™ i5-8520U | WD Blue M.2 250GB / 1TB Seagate FireCuda | 8GB DDR4 | Windows 10 Home | ASUS Vivobook 15
Intel Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance DDR3 | Samsung 850 EVO 250GB | macOS Catalina  Lenovo IdeaPad P580
iPhone 6s (iOS 13.6.1) | iPhone XS (iOS 14.3) |  iPad Mini (iOS 9.3.5) | Samsung Galaxy S5e (Android 10)
Support forums for those companies may not earn them a profit but they are nevertheless financially incentivized to run them. Forums for tech companies can help their customers solve common problems and can therefore significantly reduce RMAs and the load on their customer service department.
The only possible incentive for LMG is that this forum advertises its channels to the forum's users (both registered users and those who stumble upon this forum through Google). However, I don't think the advertisement for this forum really adds many viewers.
I think it's fair to say that this forum's relationship to LMG is more along the lines of "we like your channel and what it stands for so we bring that spirit to the forum and you like this community and so you'll advertise your channel here and invest in paying for the servers." Other than that, I think the forum is pretty detached from the channel.
Similar to my IRL relationships.
Check out
PRISON STRIPES!
R5 3600 - 2070S - X570 - H210
I should still be writing papers...
Forum Moderators are not Employees of LMG, we are 100% volunteer group.
The position that @colonel_mortis posted is not for a Forum Moderator, it is to help maintain the internal workings of the forum, this was clearly defined. It is still a voluntary position, if you are not interested then by all means do not apply, if you are interested then apply, your argument is not a subject up for debate here.
If you want to discuss further please take this to a proper place to discuss, via PM to the Admin/Moderation Team.
 COMMUNITY STANDARDS     |     TECH NEWS POSTING GUIDELINES     |     FORUM STAFF
LTT Folding Users Tips, Tricks and FAQ   |     F@H & BOINC Badge Request     |    F@H Contribution    My Rig   |   Project Steamroller
Docendo discimus - "the best way to learn is to teach" ~ Benjamin Jantz
I am a StarCitizen are you? My ships: Aegis Eclipse, Aegis Sabre, Aegis Gladius, Aopoa Nox, KI P52 Merlin, KI P72 Archimedes and the RSI Constellation Aquila.
My phones are a Samsung Note 9 and a Samsung S9+
🇺🇸   About Myself:   https://linustechtips.com/main/profile/229093-sansvarnic/?tab=field_core_pfield_46   🇺🇸
 CHRISTIAN MEMBER
Good luck everyone! Mortis, hope you find the people you need and keep this place going. You do a great job :)
Be sure to @Pickles - Lord of the Jar if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | GTX 1070 Hybrid (2100c/2241m) | Gigabyte X570 Aorus Elite | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 | Sandisk Skyhawk 3.84TB SSD | 4TB HDD
i wish i could help Comrade-in-pfp but i'm hilariously underqualified, good luck
Bethesda PC:   R7 3700X  -  Crosshair VIII hero  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Gigabyte 1660s OC -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  Lian Li PC-011D  -  H100i RGB Platinum SE  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  PNY OC GTX 1060 3GB - Asus Strix 1070Ti -  TT smart RGB 700W  -
Fractal Design Define C  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox.2: I5-6400  -  MSI B150m Mortar  -  4GB Patriot Viper DDR4 2133  -  2x Sapphire Nitro R9 Fury  -  Adata 128GB SSD  -  BeQuiet Pure Base 500DX  -  Arctic Freezer 34  -  Cooler Master silent pro gold 1000W
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
I expect to be paid entirely in warning points
Correction: a much appreciated volunteer group.
Hmmmm, I remembered Luke say that the forum job would be based on React, but I guess that was for lltstore.com and I misheard/misremembered. PHP eh?😬 good luck bois.
Edit: It was in the WAN show where he talked about two projects that they needed help for, one (paid) for lttstore.com using React and the other was the voluntary Forum project. I misremembered that forum was built on React, ofc its not, my bad 😅.
Edited by Dem1se
Any chance of a badge like the "office builder" but for forum maintenance, as some people without the skills(like myself) might like to help out in some way, like a one off donation.
CORSAIR RIPPER: AMD 3970X - 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 3600 - 1080Ti & 1070Ti - 16GB Ram - 240GB NVMeSSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
Luke hasn't been active part of forums in years. If you have heard him saying something, it must have been for Floatplane.
Forum contribution is currently only way to support forums. Both First Blood and Office Builder were for funding LMG in its early days.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
applied.
edit: oops closed the Google Forums tab so cant edit response but can I also apply for UI dev? thanks
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
laptop: macbook air 13.3”
            RAM: 4GB 1333MHz
            CPU: Intel Core i5 2557M
            SSD: 128GB
            OS: Ubuntu 20.04
            Status: Retired PC
desktop: operation badger
            RAM: 16GB DDR4-3200 CL-16
            CPU: AMD Ryzen 5 3600 @ 3.6GHz
            SSD: 256GB
            GPU: Radeon RX 570 8GB OC
            OS: Windows 10
            Status: Main PC
            Cinebench R23 score: 9097 (multi) 1236 (single)
            Temps: CPU idle 45C, load 78C, top 85C. GPU idle 50C, load ~77C.
don't some things look better when they are lowercase?
-wall03
The video uploaded properly, and then broke after editing in text below.
"...because it's a community forum that doesn't make money."
One guy doing all of this for years without seeing a penny, and he needs help from people who are passionate and willing to donate their time. If that isn't you, then don't apply.
Here's a link to the Youtube video that explains what Luke asked for.
https://youtu.be/v0t617WK10I?t=4578
Hey @colonel_mortis, I have a couple of questions if you don't mind:
1) Is using my full, real name strictly necessary to apply and if so, can I expect it not to be shared?
2) is there any sort of "beta" website we can test our changes on and use to familiarize ourselves with the codebase without fear of breaking everything or deleting user data?
3) are there going to be any strict deadlines outside of the general expectation of spending a few hours per week on this?
sudo chmod -R 000 /*
What is scaling and how does it work? Asus PB287Q unboxing! Console alternatives :D Watch Netflix with Kodi on Arch Linux Sharing folders over the internet using SSH Beginner's Guide To LTT (by iamdarkyoshi)
Sauron'stm Product Scores:
Just a list of my personal scores for some products, in no particular order, with brief comments. I just got the idea to do them so they aren't many for now :)
Don't take these as complete reviews or final truths - they are just my personal impressions on products I may or may not have used, summed up in a couple of sentences and a rough score. All scores take into account the unit's price and time of release, heavily so, therefore don't expect absolute performance to be reflected here.
-Lenovo Thinkpad X220 - [8/10]
A durable and reliable machine that is relatively lightweight, has all the hardware it needs to never feel sluggish and has a great IPS matte screen. Downsides are mostly due to its age, most notably the screen resolution of 1366x768 and usb 2.0 ports.
-Apple Macbook (2015) - [Garbage -/10]
From my perspective, this product has no redeeming factors given its price and the competition. It is underpowered, overpriced, impractical due to its single port and is made redundant even by Apple's own iPad pro line.
-OnePlus X - [7/10]
A good phone for the price. It does everything I (and most people) need without being sluggish and has no particularly bad flaws. The lack of recent software updates and relatively barebones feature kit (most notably the lack of 5GHz wifi, biometric sensors and backlight for the capacitive buttons) prevent it from being exceptional.
-Microsoft Surface Book 2 - [Garbage - -/10]
Overpriced and rushed, offers nothing notable compared to the competition, doesn't come with an adequate charger despite the premium price. Worse than the Macbook for not even offering the small plus sides of having macOS. Buy a Razer Blade if you want high performance in a (relatively) light package.
-Intel Core i7 2600/k - [9/10]
Quite possibly Intel's best product launch ever. It had all the bleeding edge features of the time, it came with a very significant performance improvement over its predecessor and it had a soldered heatspreader, allowing for efficient cooling and great overclocking. Even the "locked" version could be overclocked through the multiplier within (quite reasonable) limits.
-Apple iPad Pro - [5/10]
A pretty good product, sunk by its price (plus the extra cost of the physical keyboard and the pencil). Buy it if you don't mind the Apple tax and are looking for a very light office machine with an excellent digitizer. Particularly good for rich students. Bad for cheap tinkerers like myself.
Newegg
