Search In
  • More options...
Find results that contain...
Find results in...
How bad is of 27gn850 monitor in a dark room, for gaming, and coming from a tn panel?
Hi,
Looking at getting a new monitor for mainly first person shooter games.
I will be coming for a 1080p 24" 240hz TN panel
Does anyone have a dual setup of different resolution monitors?
Will be pairing it with a rtx 3000 series card.
Cheers
Jim
I have the 27GL850 which is the 2019 model, same panel on it. NO issues with it personally in dark environments. I work overnights and keep my office lights off a lot to help my eyes and notice little to no issues with it. I also have a cheap junky 1080p monitor on the same system with no issues.
PSU Tier List Thread
"White Ice"
Ryzen 7 3700x | Asus Crosshair VIII Hero (Wi-Fi) | EVGA RTX 2080ti | Ballistix 32gb 16-18-18-38 3600mhz | Full Custom Water Cooling Loop | 1tb Samsung 970 Evo
2tb Crucial MX500 SSD | 2x 3tb Seagate Drive | Fractal Design Meshify S2 |  EVGA G2 750w PSU | 3x Corsair LL140 | 3x Corsair LL120
Dedicated Streaming Rig
 Ryzen 7 1800x | Asus B450-F Strix | 32gb Gskill Flare X 2400mhz | Corsair RM550x (2018) | EVGA GTX 1060 3gb | 250gb 860 Evo m.2 | Phanteks Enthoo Evolv
 Elgato HD60 Pro | Elgato 4k60 Pro mk.2 | Avermedia 4k GC573 Capture Card
I have 2 of the 27GN850's and have absolutely no issues. Pretty much always playing in a dark room because it's always late when i use my PC. Even for an OLED owner like myself it's still not as bad as many make it out to be. Other LCDs may have better contrast but coming from OLED every LCD monitor has "bad" contrast. I wouldn't worry about it. Otherwise it's basically a perfect monitor.
Using 2 different resolution monitors is no problem, but scaling might be a bit different for each monitor.
PSU Tier List          AMD Motherboard Tier List          SSD Tier List          How to choose a Monitor
Current Specs:
CPU: AMD Ryzen 7 3700X - Motherboard: MSI B450 Tomahawk Max - GPU: PNY RTX 3080 XLR8 Epic-X - RAM: 16 GB Crucial Ballistix 3600Mhz - PSU: Corsair RMx 850W - Storage: 500 GB Samsung Evo 850 2,5" (OS) + 2 TB Samsung Evo 860 M.2 (Mass storage) - Cooling: EK & Alphacool custom loop - Case: CoolerMaster H500 - Fans: 6x Arctic P12 PWM PST - AMP/DAC: Creative Sound BlasterX G6 - Fan Controller: Corsair Commander Pro - OS: Windows 10 Pro - Monitors: 2x LG 27GN850-B HDR-Gaming-TV: LG C9 OLED 55" - Mouse: Logitech G Pro wireless + Powerplay - Keyboard: Logitech G910 Orion Spectrum, Corsair K63 Wireless + Lapboard - Headphones: Beyerdynamic DT990 Edition 600 Ohm - Microphone: Antlion ModMic
Thanks, I was wondering if reviewers were laying it on think with regards to the brightness issues, or just going by stats without testing.
I was looking at the 27gn950, but at twice the price, sporadic availability, 27inches, I  am starting to think, high 1440p over 144fps, may just be as good as low 4k 120fps.
Graphics settings are always more important than resolution. Even High 1080p would look better than Low 4K. Also at 27" you will barely notice a difference between 1440p and 4K, but you will certainly notice the better performance with 1440p. There is no point in going for 4K if you then have to turn down the settings imo.
Current Specs:
