Please help, Laptop Screen has faint darkish line on left corner
Solved by shoutingsteve,
Are you able to get into the BIOS, during the BIOS screen, you will be outside the windows environment and we can at least tell if it is hardware at that point. If it persists int he bios screens, then it is a hardware problem. if not, then it is an issue inside winodws and might just need a reinstall of the graphics drivers.
PatRed ·
1
1
StormBreakes ·
Posted in Build Logs0 -
3
Jojo0607 ·
Posted in Peripherals4 -
1
Siper_ ·
Posted in Graphics Cards2 -
ShadeBorderlands ·
Posted in Programs, Apps and Websites3
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
