Search In
  • More options...
Find results that contain...
Find results in...
affordable GPU for rendering and 3d modeling
Hello friends
I was planning to build a midrange workstation for animation and rendering
I know the basics of parts but i don't dence of clocking, overclocking,RAM timing, voltage and more.
i have searched a bit of workstation for 3d and 4K rendering and thought to get with this configuration-
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor
Memory: G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive
still i am unable to find a perfect mid-range gpu, motherboard, and power supply
i was looking for GeForce GPU but the rtx 2070 and greater are beyond my budget
if anyone knows the perfect affordable gpu for rendering please suggest
evga 2060 ko has compute performance rivaling the 2070 due to using a 2080 die. ~300 usd, best bang for your buck for compute/rendering workloads
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
You can render on an nVidia 8800 GT, if you're patient enough 🤪
But until we know your budget, it'll be hard to suggest something
So rise up, all ye lost ones, as one, we'll claw the clouds
i think the old 1080's are probably cheap enough these days and would be decent
my budget $800
5 minutes ago, kdsounak said:
my budget $800
For the GPU alone, or for the entire system?
i was thinking of 1080ti but heard 2ndhand rumours about its threshold problem
what you say?
gor the entire syst 😅
if i get $800 for gpu alone it won't be the matter to discuss from the first
what you say?
buy one that has a good return policy from the seller then
Newegg
