White PSU for 3080
StrafeJog
Looking for a new PSU, I'd like it to be white because I've just bought the Lian Li 011 in white, and I'm going for a black and white themed build.
I know that limits my options, but it can also be black with white lighting or white motifs.
I've seen Corsair RMx in white, sadly in Switzerland on the 750w is in stock, and I'm not sure, given the transient spikes (and that I will overclock it at some point), whether that will be fine. Maybe I'm being overly paranoid.
Options?
750 is enough for overcloking the gpu and cpu. what will yoru cpu be?
rtx 3080 overcloked and ryzen 9 3900xt overcloked uses around 600-650w. withotu azny oc around 520-570w. you are fine with 750w
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
Yea but it's not the average load I'm worried about, it's transient spikes. I already have a top-tier PSU that shuts down with high transient spikes.
I'm just wondering if this model CP-9020187-EU is the new design or an older design, as there really aren't any other white models available.
That's the newer ("2018") version of the RMx white. You can tell as it's shorter than the older one, and it has grouped white sleeved cables - the older one had individually sleeved cables.
CP-9020155-EU is the older version.
Thought you meant an 80+ white PSU for a 3080, nearly triggered myself.
Seasonic Snow Silent or Focus White ?
Black cables though... I think.
Yes, looked at those too but they're out of stock
750W RMx should be good, Corsair tested RM 2019 with RTX3080, it worked, RMx 2018 is very similiar.
Tag or quote me so i see your reply
