i need help with the hp dv5 laptop from 2008
Go to solution Solved by SupaKomputa,
well first if you wan't an instant boost you need to buy a SSD.
second you can upgrade the ram to 6 or 8gb, that is if you can find 4gb ddr2 modules (it exist, i have one).
third you may want another HDD for extra space, you need to buy a HDD Caddy to replace your optical drive.
Fourth, you can actually upgrade the CPU to Quad core if the model supports it. But this kinda experimental, so you've been warned.
Well that's all you can do.
That laptop is too old.
i need help with the performance and the laptop fan soo yea
also some performance upgrades please
also the laptop specs is: geforce 9800g gt graphics card
and the cpu is: core 2 duo t9400
and the memory size is: 3 gb
and i have 1 hdd with 3 partitions on it with its full size bieng 438 gb
well
it still works and has a better gpu than integraded graphics from the ony other pc i have
Other than getting a SSD and maybe upgrading to the maximum support RAM capacity of 8GB, not much you can do.
4 minutes ago, Gamer69epic said:
i still works and has a better gpu than integraded graphics
Doubt that thing would be able to pull off 4K YouTube.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
ok good i thought this thing was just donezo i thought i would'nt be able to play minecraft on it but now i can with the info i have thanks alot
That is actually false. Intel hd graphics have long since gone far past the performance of a 9800 gt mobile.
Current minecraft will be very hard for that machine to run. Also quote people.
3 minutes ago, Gamer69epic said:
also it can only handle 6 gigs of ram so yea
Maximum supported memory size seems to be 8GB.
References: https://support.hp.com/lv-en/document/c01630393https://www.cnet.com/products/hp-pavilion-dv5/https://www.crucial.com/compatible-upgrade-for/hp---compaq/pavilion-dv5-1235dx
2 minutes ago, Gamer69epic said:
also should i update the bios
Again quote people. Leave the bios alone and it supports 2x4gb of ddr2 sodimm.
well better than a core i7 2th gen
no way. even the slowest i7 will blow your cpu away.
but how?
get a 4gbx2 memory module
no need.
also not to be annoying but could you make i list that i could write down
