Fans for my Pc
Sushunuchi
P12 pwm and p14 pwm from arctic are ranked very high and are easy on the wallet.
I like deep cool lighting strip as it lighting is solid, it magnetic and also easy on the wallet. But what type of strip you get will depend on what rgb header your motherboard has
5 hours ago, Sushunuchi said:
What kind of light strip are you planning on using? Is it RGB? What motherboard do you have, and what kind of RGB is compatible with it. Are you just planning on using standard non-RGB LED strips? Do you want your case fans to light up. Do you plan on using a liquid cooler, if so are you planning on keeping the fans that came with it? What do you want out of your fans, silence, airflow, static pressure? What kind of noise do you prefer, low or high frequency?
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
