Search In
  • More options...
Find results that contain...
Find results in...
Best cooling for ITX build?
Go to solution Solved by DailyProcrastinator,
15 minutes ago, Newbie.Builder said:
Ok, I didn't know you could with the shift air. I'm planning on getting a 3070.
Ahhh the Shift Air... Lol I missed that. Regardless, a 120mm AIO is a better option when the only air cooler alternative is a slim cooler (with regards to cooling performance). Worth the price increase for sure in this case. I opted doing this for my SFF ITX build, my H60 easily outperforms my slim cooler (Cryorig C7).
Typically 120mm AIO's are not recommended where a tower cooler that's half the price will outperform it, but that is not an option in the Evolv Shift.
I would recommend:
https://nz.pcpartpicker.com/product/F2rmP6/corsair-h60-2018-572-cfm-liquid-cpu-cooler-cw-9060036-ww-cfm-liquid-cpu-cooler-cw-9060036-ww
EDIT: Links for NZ pricing
Hi guys, I am currently going to build a PC in the Phanteks EVOLV SHIFT air case. Unfortunately, I can only fit a 120mm rad in it. Would getting a Corsair H60/H80i and swapping the stock fans with good Noctuas  be a reasonable idea? I'm going to get a r7 3700x or a 3800xt so would this be sufficient? or does anyone have a better idea? I would also not like to switch the case.
Thanks.
H80i would be more than enough for both CPUs. the Corsair stock fans are actually quite good, well optimized for radiators and super quiet. (obviously not BeQuiet or Noctua quiet but I would challenge people to blind test the difference when using PWM)
Current Config:
R5 2600X @4.1ghz all core, 16GB Patriot 3200mhz, 1TB XPG SX8200 Pro nvme, RTX 2070 Duke, CM Elite 110 mitx, pair of KRK Rokit 6 monitors with 10in sub, BenQ TH671ST projector for 150" screen.
MSI Prestige 14 with too many cooling mods to list out (it's quiet now)
Even while overclocked? Also I just realised that i may only be able to use one of the fans because of graphics card height, would this have much of an issue?
120mm rads aren't worth it. See if you can snag a low profile noctua instead
Yeah I've heard about that, however I'm not too fussed on pricing on them as long as they work fine and look clean enough. Unless the Noctua has better performance I personally would rather get a a quality AIO. Which would you say has better performance?
You'd have to look at GN's graphs and what fits in your case. Typically a tower cooler will function better than an AIO, especially a 120mm AIO
Yeah I know tower coolers are good, I would be getting one if it fitted. My case only supports low profile coolers, stock cooler doesn't fit either, so no way a tower could fit. would it be better to get a low profile cooler like a Cryorig c7 or the 120mm?
2 minutes ago, Newbie.Builder said:
Yup it does fit. Does it come in a chromax variant, and will it outperform a 120mm AIO like the H80i?
It does
https://amzn.to/33sxv4G
and probably
I wouldn't get slim cooler over a 120mm AIO, performance will not be as good. Also, you can fit XL sized air coolers in the Evolv ITX including a 240/280mm AIO. What GPU do you have?
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3900XT  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA 850W P2 W/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair SCIMITAR PRO RGB
Torrent  R7 3800X  Asus B550-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro (White) 2x8GB 3200MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  EVGA 750W P2 W/ Black/White Sleeved Cables  Corsair H100i Pro AIO  Corsair ML RGB Fans  NZXT H210 TG ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
J.A.R.V.I.S.  R7 1700  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance LED 2x16GB 3200MHz CL15 (Blue)  Asus RX 580 Dual Series 8GB  Corsair SF 450W  Corsair H60 AIO  Noctua NF-F12 Chromax Fans  FormD T1 SFF ITX Case
LG 32MU99 4K 60Hz IPS  OLKB Preonic V3  Logitech MX Master 3 Advanced Wireless
Gaming PC  i7 6700k  Asus Z270-G Gaming Wi-Fi mATX  Corsair Vengeance LPX (White) 2x8GB 3200MHz CL16  Asus RX5700 Dual Evo OC 8GB  Corsair TXm 550W W/ White Sleeved Cables  Cooler Master MasterLiquid ML120L RGB AIO  DeepCool RF120 RGB Fans  Thermaltake Versa H18 TG mATX Case
ViewSonic Elite XG240R 1ms 144Hz TN FreeSync  Logitech G610 Cherry MX Brown  UtechSmart Venus MMO w/ Omron Switches
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 Mini ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size Hot Swap-able  TOFU96 90%  XD84 75%  Keycool KC84 75% Wireless RGB Hot Swap-able  KBD67v2 MKII 65% Hot Swap-able  Drop Carina 60% RGB Hot Swap-able  Southpaw75 60% W/ Left Numpad  OLKB Preonic V3 Ortho Linear  Cospad 20% Numpad
Mechanical Key Switch Collection  Zealios V2 65g  Invyr Holy Panda  C³ Kiwi ‖ C³ Tangerine ‖ Kailh Box Heavy Dark Yellow  Kailh Box White  Kailh Purple  Gateron Black  Gateron Brown  Cherry MX Black ‖ Cherry MX Brown
Key Cap Collection  Star Wars GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck  GMK Nines ‖ Matt3o MT3 /dev/tty  Drop Skylight Horizon ‖ Glorious Black Aura
Overclocked, maybe. if you don't mind running north of 70C when maxed out
https://www.kitguru.net/components/cooling/henry-butt/corsair-hydro-h80i-gt-liquid-cpu-cooler-review/6/
this review runs a i7-3930k overclocked (has a stock TDP of 130W) and it handled it just fine.
Current Config:
I would recommend:
My Builds:
MEGA Desk Build
I would recommend:
OK sweet, thank you so much.
No problem!
My Builds:
MEGA Desk Build
