is there way to have 144hz output with external monitor?
Hi,
So I bought legion y540 few months ago and I want to buy new monitor that I can use as a external monitor. I would like a 144hz output but don't really know if HDMI will be able to do that.
Is there way I can achieve this? Do I need to buy a specific monitor to get it working?
Thanks for helping!
If you have an HDMI cable and a 144 Hz monitor, it should work fine. You may need to go to Display Settings, Advanced Display Settings, Display adapter properties for Display [n], Monitor, and set the refresh rate to 144 Hz.
You should be able to with mini displayport and an adapter to displayport. I got one that did 144hz through displayport and DVI-D, both worked fine.
3700x, Asus B450i, 16GB Corsair Vengeance RGB, Gigabyte GTX 970 ITXDan A4-SFX, SX600-G, 120mm AIO.
If you have a thunderbolt on your laptop you should be able to adapt it to a a displayport for your external monitor. For what i now it's the way that monitor accept 144hz
