are the arctic p12's silent fans?
bluehillday
i'm looking to mount 2 arctic p12 120mm as intake and one in the top side of the case , my mobo is cooler master mb511. i have a bequiet silent wings 3 as exhaust and it's really silent even at 1000rpm but those are expensive. wonder if the p12's are noticeble up top 800-1000rpm
The p12's are even more silent. Basically a tiny bit less than noctua level performance/quiet.
they are really cheap like 4EUR here that's why i was considering them
I have them too replace my bequiets sw2's as the p12's perform better and are more silent
From seeing a review of them, they are really quiet. As long as they are not running at 1000rpm though.
but do they make that annoying motor noise? not talking about the air whoosh.
I have 10 running in my system on my radiators, the sound they produce at max is pleasant compared to other fans (I run them at max) - I highly recommend these fans as an affordable, performing option.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
The pwm pst and the regular p12's don't have that noise oddly enough. I don't know why but it is like that.
You mean the p12 s non pwn 1800rpm?
Both the normal non pwm p12's and the pwm pst p12's do not experience that issue.
The P12 PST for my setup seem fairly quiet. I don't really hear anything until my ears are 2 feet away from the case while under light CPU loads. I usually keep my fan RMP from 500-900 and up to 1300 RPM on stressful loads. I do hear some kind of sound somewhere above 1200 RPM at times when the fan revs up and down when the CPU gets really hot. I corrected things by adjusting the higher temperature range and RPM from bios. I don't see it as a flaw in the design.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
They are quiet but not really silent.
If you have shitty hearing and claim everything is 'inaudible' maybe. I've heard people say their H100i / H150i is inaudible under full load with a 10700K.
Keep them below 1200 RPM at max load and you'll be good.
As a wise master once said,
Put as much effort into your question as you would expect a stranger to add to their answer!
Desktop: AMD Ryzen 5 3800XT | Gigabyte X570 Aorus Ultra | Corsair Vengeance LPX 32 GB 4000Mhz CL18 | MSI RX 5700 XT Gaming X | Two WD Black SN750 1TB NVMe SSD | Corsair AX850 Titanium | Fractal Design Define 7 White, Solid
Laptop: Apple Macbook Pro 16 | i9 9980H | 16 GB RAM |  1TB SSD | AppleCare+ | Space Grey
Peripherals: RAMA U-80 Lake | Logitech MX Master 3 | Kanto YU2 White + Beyerdynamic DT 177X GO
Displays: LG GX 55"| Acer XB273K | Dell Ultrasharp U2720Q | LG 32UN650-W
