Building my first PC. Is it compatible?
So I'm wondering if this is all compatible? Does the motherboard support the 3600mhz ram? Is it enough power? Planning on adding another Nvme ssd for extra storage later on, is that possible for that motherboard? Does the case support a top mounted radiator for the cooler I'm choosing? Does the cpu support 3600mhz ram?
Any tips or suggestions?
Motherboard- Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard
Cpu & cooler- 3700x and the Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler
Ram- Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
Storage- Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive
Gpu- 3080
Psu- Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Case: Phanteks Eclipse P400A Digital ATX Mid Tower
Any help will be appreciated 🙏
It's compatible. The 970 is expensive, you'll get similar performance from something like an SX8200 Pro.
As for the questions about compatibility, if you go to the Asus website and check the manual you'll find your answers. They also have a RAM QVL list that will tell you if the RAM has been checked to work with the motherboard.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Yes, it's all compatible.
If you aren't already, use pcpartpicker.com, it's wonderful, checks basic compatibility automatically (although you should still always perform a final check for yourself), and finds the lowest prices.
Keep in mind that by the time you can get a 3080, Ryzen 4000 CPUs will be even closer. (they're probably releasing sometime before the holidays, nobody knows for sure)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
