RTX 3000 Series PCIe 4.0 Required?
Alazam
The specs for the RTX 3000 series cards say PCIe 4.0 so does this mean you can't use them on a motherboard without PCIe 4.0? I have an 8700K and don't want to have to upgrade to a new motherboard and processor already...
No, PCIe is backwards-compatible.
1 minute ago, NoobBoi said:
It'll work, but you'll lose performance.
We haven't had any benchmarking so nothing can be said for sure. However, I wouldn't expect most applications - particularly games - to require the PCIe bandwidth of gen 4.
Seriously doubt this, as only the 2080Ti saturates the PCIe 3.0 8x pipe when going SLI.  Nowhere near the limits of PCIe 3.0 16x are being touched.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Actually, according to the presentation, it will likely greatly affect load times in games since it sends the textures/etc. directly to the GPU for decoding, rather than into the CPU and system RAM.
CPURyzen 7 5800X Cooler: Arctic Liquid Freezer II 120mm AIO with push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
MotherboardASRock X570M Pro4 GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO Case: Antec P5 PSU: Rosewill Capstone 750M
Monitor: ASUS ROG Strix XG32VC Case Fans: 2x Arctic P12 PWM Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
Interesting.  Didn't see the presentation.  Load times or actual FPS being affected?
OnePlus:
Other Tech:
Load times, possibly FPS if you're doing one of the "no loading screens" games. The presentation is short, and I would recommend watching it.
I will.  Only thing I can see would be them saturating the PCIe 3.0 16x pipe, as the access speed of PCIe 4.0 isn't faster if I read correctly.
That's a LOT of data being thrown around then.
OnePlus:
Other Tech:
56 minutes ago, Alazam said:
there's no confirmations yet but there's a high chance there will be performance loss using pcie 3.0, zen 3 looks to be optimal for ampere since intel...shat the bed.
That said it'll work with the 8700k, we'll find out how much performance is lost before the cards even come out so we can make informed decisions.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
looks like not at all check their video again there is small writing on bootom of screen that they test it on i9 cpu so thats pci 3.0
thats interesting, thx for the info, can confirm it :D
lets wait for the reviews coming in and check the performance difference between 3.0 and 4.0 and hope for the best( i dont want to have to change my mb if i would buy a rtx 3070 )
Edited by Ruboka
typo
Desktop PC:
Ryzen 5 3600 @stock - Noctua NH-U12S-SE-AM4-  B450 Gaming Pro Carbon Ac - Powercolor Red Devil RX 5700XT -
32GB (16x2) Ballistix Sport DDR4 3200Mhz 16-18-18-36 -
250GB Samsung 850 EVO SATA - 1TB Samsung 860 EVO SATA - 500GB WD Blue SATA M.2 - Corsair TX 750M - NZXT H500 - Benq GW2765 -
ViewSonic VS2778  SMHD -  Logitech G105
Audio Gear:
Teufel Concept E 100
Sennheiser Game One
Creative Soundblaster X3
PCPartPicker:
https://pcpartpicker.com/list/YVzK4n
