Search In
  • More options...
Find results that contain...
Find results in...
tried to delid i7 6700k no post
I tried to home delid i7 6700k, not using liquid metal. I opened cpu fine wiped old thermal paste. When I put cpu to the mobo system is not booting nor post, no beep sound. Can be that I damaged cpu?
Core seems to be chipped in 3 places? Might be the cause...
... but I'm no expert.
the die looks chipped
My PCs: Desky | Beddie | Miney | Benchie
Things I need help with: (nothing at the moment)
none atm
I hate Intel's pricing, Ryzen's weird quirks, Nvidia's pricing, and Radeon GPUs in general
Products I like:
Sony Xperia Z1 / Z2 / 10 ii, Asus Strix 970 / 1070, Samsung SSD, WD HDD, Corsair PSUs (AX, RM, CX(grey)), GeForce GPU, NZXT N450/S340, be quiet! Coolers, G.Skill Trident RAM, Logitech M525, Logitech G440, Razer Deathadder Elite
Products I hate:
Xperia Z3, XiaoMi 5c, Radeon GPUs, Razer Audio Products, any bloatwares
Companies I absolutely adore: (and hope it stays that way)
be quiet! - sent me AM4 mounting for my DRP3 even though it's way past the timeframe stated, no questions asked
Corsair - very good RMA experience, absolutely recommend
Companies I hate:
Nvidia, Intel, Apple, TMT (Thundermatch, a retailer)
Personal Blacklisted Companies:
Acer: shit tier quality products, shit tier customer service thus far, they "tried" to solve my issue but they arent really doing anything but delaying and delaying. (on-going case since July)
Gigabyte: horrible customer service (gigabyte had literally 0 customer service, asked me to go to retailer with NO WAY to email them about a question) but at least they fixed my shit in ONE MONTH (would probably take me 1 hour to fix if they let me email them)
XiaoMi Phones: built like a tank but the software is buggy as all hell
Seagate HDD: had too many dead seagate drives
Kingston SSD: 300V controller swap thingy
Razer (except their mouse)
Remember, just because I had good/bad experiences with these companies/product, doesn't mean you will have similar experiences too. I would still recommend these products if they made sense for your needs, but I'll add a disclaimer of my experience if it's relevant. Feel free to DM me asking why they are where they are.
Need a lot better of a picture to really see what's going on.
But from the first picture, the razor blade looks to have cut the PCB a bit and might have hit the tracing.
Right there where your thumb is.
- If it ain't broken, don't fix it! - - Your post codes and beep codes in the drop down below -
Chips in silicon won't stop the cpu from working. The core is burried in the bottom of the PCB.
i know that, cant tell how much it's chipped
it may as well be a badly scratched trace
did you try to check the bottom of the cpu as well?
none atm
Products I like:
Products I hate:
Companies I hate:
Well it looks like PCB damage. Cut tracings is the culprit.
Definitely do not need to use nail polish unless you're using Liquid Metal.
Do you have a better camera, your phone is doing a horrible job (no offence) just can't see anything with good detail here.
There is a contact pad missing at the top by the middle finger.
This cpu is mangled up lol.
Just now, Drevo said:
fans are spinning, cpu is getting hotter and no usb power
tried resetting cmos?
did you try to boot bare die?
none atm
Products I like:
Products I hate:
Companies I hate:
I think this CPU is damaged beyond repair.
Always good idea to check on another board, but seems damaged too much.
i tried to reset cmos ( remove battery wait and put it back) tried to boot up without heatsing pulling cpu with finger untill hot
What kind of razor did you use?
That's a knife.
Next time use a thin shaving razor.
Something like this....
picture from my tutorial 2009.
Honestly all this is why I wouldn't even consider de-lidding unless I had practiced on junk CPUs prior (like the ones you can get from ebay for like £5), and would still have a PC to use if it went tits up.
How much benefit can you even get from this, isn't the IHS supposed to help cooling by providing a wide contact area? If it reduces heat transmission by any appreciable amount, wouldn't they make the lids out of copper instead?
