NVidia 3080 and 1080p Help
Omikse
Since I am having trouble with finding or getting help with 1440p monitor, I will ask this question. What disadvantages would a 1080p with a 180hz refresh be when using a 3080. I think enough specs have come out to give an educated guess as to how it will handle. So, any speculations?
OS: Microsoft Windows 10 Pro, Motherboard: ASUS Crosshair VI Hero, CPU: AMD Ryzen 5 3600, Heat Sink: AMD Wraith Prism RGB, Video Card: FTW GeForce RTX 3080, Memory: 4 x G. Skill Trident Z RGB Royal 8GB (total 32GB), Power Supply: Thermaltake Tough Power Grand RGB750W, MonitorAOC Q32G1WG4, HD: 2 x Samsung EVO 850 and 4 x Seagate 2TB ST2000DL 003-9VT166 SATA HD, Keyboard: G. Skill RipJaws KM780R RGB Mechanical Keyboard, Mouse: Logitech G903 Wireless, Network Adaptor: D-Link DWA-192 AC1900 Wi-Fi USB 3.0
The disadvantage would be lower reselution
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
That card is built for 1440p and 4k gaming. It would easily get over 240fps in most games maxed out at 1080p
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
In that case what would be better 1440p or 4k?
Nope. The only thing we remotely have is for the 3090, and that's just pretty pictures and some vague info about the cooler design and new 12-pin connector. Any performance info is entirely based on rumors, and again, tells nothing about the lower tier cards.
That said, a 3080 should at least be better than a 2080, so since a 2080 can pretty much get you 144fps at 1080p in a lot of games, you'd probably do even better with a 3080.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
So a 1080p monitor would be ok as long as the refresh rate was 144hz or higher? Or does it have to be 1440p or higher?
I honestly have a feeling like the lower tier of the 3000 series will be around the 2080's performance. IT would only make sense to me.
You're kind of thinking in reverse. You can get a CRT monitor from the 80's (assuming you could find a compatible connector to actually hook it up to the graphics card). The thinking should be what resolution and FPS do you want to play at, and then buying a monitor and graphics card to match.
If you want 1080p at 144fps, then yeah, buy a 1080p 144hz monitor. If you want 1440p, then get a 1440p monitor. The graphics card, then, is just a function of feeding the display with the resolution and refresh rate. The higher the resolution/refresh rate, the beefier of a card you'll need, obviously. However, the games you play are an important factor as well. Some games, like AAA titles, you're just not going to be able to push at 1440p 144fps, no matter what card you have. But, something like CS:GO, you could push that high or higher even without a top of the line card.
I obviously want to play at the best resolution and FPS that I can get, which is why I am asking my question.
Which brings back to the question. I do want to get a 3080 card. I have settled for budget or use (yes I know there is nothing wrong with a budget or used card) but for once I want to be able to get a top tier brand new product. And I just want a monitor that will handle it if I do want to play those AAA game at a decent resolution and FPS. So if a 1080p monitor will not mix well with an RTX 3080 when it comes out, then I do not want to pair them together. Which will reduce my card budget fund that much more since I am dipping into it to get a monitor as well.
I do want to say thank you because you are helping me in my understanding in what monitor should go with what card or game. And that is a big help.
the only reason to get a 1080p monitor with a 3080/3090 would be the 360hz monitor that's coming out, but even at 240hz, there aren't cpus that are strong enough for 240hz/360hz on AAA games, so for those 1440p/4k 144hz is recommended, the 3090 should fall short of 4k/120fps without dlss on AAA games while the 3080 will be good enough for 1440p/144hz, with a few exceptions, ps4 ports, rdr2, hitman.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
And that seems to be the answer I am looking for, whether I like it or not. So I will try to stick with a 1440p monitor when it comes to the 3080. Now if I can just find one low enough that is doesn't wipe out my Card budget fund. I am trying find a 32in curved around 300 usd
If you want a good monitor, that will be tough. You would have to go with low budget VA panel which will have ghosting problems.
For under $400 this would be your best bet, and it suffers from ghosting and lots of overshoot in many transitions and isn't curved.
https://www.rtings.com/monitor/reviews/lg/32gk650f-b
This would be cheapest curved 32" monitor at $430. And it still suffers from ghosting problems.
https://www.rtings.com/monitor/reviews/samsung/chg70
You should read the sticky as it has lots of good information about monitors.
That was my point. There is no "mix well" calculation here. It will drive a 1080p monitor just fine. Could you maybe push higher resolution? Sure. At the FPS target you want? Maybe. Want to make sure you get the best visuals? Then go for the 1440p. You can still run at 1080p if you need/want to, but then you'll get 1440p as well. Might you need to make some sacrifice to your FPS target or visual settings to run at 1440p? Maybe. Depends on the game. A better GPU just gives you more headroom for these decisions. A lesser GPU starts to make the decisions for you.
I have read that thread and I am trying to make use of it. But the budget I have to work with means I am going to have to make sacrifices for it. Unfortunately the 2 monitors you listed are outside that budget by at least 100 dollars. This is a range that I am more hoping for but do not know if it is a goo monitor or not
MSI Optix MAG322CR
or
SAMSUNG C32JG56
I have seen many close to or around 300 usd those under are 1080p with those above being 1440p
MSI Optix MAG322CR
or
SAMSUNG C32JG56
If I were in your shoes, I would buy the GPU when it comes out and keep using the old monitor till I have saved up enough money to buy a decent one.
The card will work just fine with your old monitor. While it might not be optimal, at least you won't have any regrets about buying a bad monitor you don't want to keep.
1440p 240Hz is a good option.
1440p 144Hz if budget won’t get you that far.
1080p should only be considered again if you’re looking at 240Hz or the upcoming 360Hz.
if you want a screen for a long time,
4K 144Hz makes sense to enjoy games in SP at 60-144FPS & MP at 80-144FPS depending on settings / game.
You need to decide which way to go, then look at which monitors in that spec.
