What is DisplayPort 1.4 Display Stream Compression
Solved by mariushm,
It's a real time near lossless image compression ... the video card compresses the image on the screen and sends it to the monitor, and the monitor must have a processor powerful enough to decompress the frames as they come.
The image compression is something like... let's say a mix between PNG images (lossless) and JPG 95% or better, basically difficult to spot artifacts... but it's not lossless, bit exact.
DSC must be supported by the processor inside the monitor.... so if your monitor is old it won't be supported.
See VESA and MIPI Announce Display Stream Compression Standard
and the whitepaper here that's more technical : http://www.vesa.org/wp-content/uploads/2014/04/VESA_DSC-ETP200.pdf
