Best compromise for "silent" case?
Ironically "silence-optimized" cases are not the best way to make a quiet system.
In most cases you get better noise AND thermal performance by going with an airflow-optimized case so you can just reduce fan speeds while your components also have great temps. I have a CoolerMaster H500 completely kitted out with Noctua fans. You can't go quieter with any silence-optimized case, as you need some fan speed (and noise) to overcome the little air vents they have and not have your components stuck in an oven.
24 minutes ago, homeap5 said:"Hotter" usually means 1 degree difference. Don't worry about it.
Get BeQuiet Silent Base 600.
"Hotter" can usually also make a difference of 20°C. Just have a look at the case reviews from GamersNexus. The best noise-performing cases are always the airflow cases with slower fans. If you have a CPU running at 75°C, another 20°C from a bad case with no airflow can make the difference between thermal-throttling and not throttling.
Good cases to base a silent build with air cooling on are for example:
beQuiet PureBase 500DX
Phanteks P300A, P400A, P500A
Fractal Meshify C, Meshify S2
CoolerMaster H500, H500M Mesh, H500P Mesh, TD 500
LianLi Lancool II Mesh
Just go for good airflow, big heatsinks and slow fans. This is the way to get a truly unaudible (silent) system like i did and still have good temps too.
