Where should I put my 5th case fan lancool 2
BlazerBuddy
I have the lian li Lancool 2 and have a 5th fan that I don't know where to put, my current fan orientation is 2 front 1 top 1 back. Should I change it to 2 front 2 top and 1 back or 3 front 1 top 1 back??
Just now, BlazerBuddy said:
Okay XD
post a pic when done ;)
What size are your fans, and specifically the 5th fan? You can only do three up front if they're 120mm. If they're 140mm, you only get two. I would avoid the top front, as you're just working against yourself with that. A front top exhaust is going to just immediately eject the fresh intake from the front, and a front top intake is going to create vortexes that will also prevent the fresh intake from reaching your components.
If you can, I'd use the extra fan to do 3 front intake. Otherwise, just leave it out. Just because you have 5 fans doesn't mean you must or even should use all 5 fans. More fans doesn't equal more better.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
I have all 120mm fans, I will just put the 5th fan in the front like you said. Half of the fan will be going straight to my gpu, and the other half right under my power supply shroud.
