Monitor
Betmens
Hi!
Someone might suggest a good gaming monitor 2k resolution 144hz?
budget up to 450 Euro
ah crap whats that LG that everyone likes
https://www.amazon.com/LG-27GL850-B-Ultragear-Compatible-Monitor/dp/B07TD94TQF
pretty sure anything that uses this nano-ips panel kicks ass, but theyre always out of stock. usually around $400
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
Tnx :)  You think 32inch  is good or 27  better ? My specs i5 8400, gtx1080ti, power supply Corsair 600w
screen size is more preference, depends on how far away you sit and that sorta thing. id personally prefer a smaller screen than 27 inches but thats about as small as they usually come. the 8400 may not be able to push 144hz without stuttering so you could consider either a cpu upgrade or get a 60hz 4k monitor.
O thanx man for advice , and soory for my bad english , whats about i7 8700k or i5 10400?
if you have a z370 get the 8700k or possibly a 9th gen, if you have a b or h series board i'd suggest either a 10600k with a new mobo or a ryzen system with a 3600/3700x
i have a b-360 pro4 , i think better wait for ddr5 and get 10600k with new mobo
Inches of display doesn't matter. If you have a 27" 2k is the same as a 32" 2k
If other characteristics are the same. Resolution and fps will matter mostly.
Also an old game is easier to run in higher settings. So you better be specific if you have specific demands :)
well when ddr5 comes out it'll be on completely new boards that will likely not be backwards compatible and theyll be expensive as shit lol, perhaps keep an eye out for used z370/z390 boards online or locally, its kind of a dead socket so the mobos are comparatively cheap
Do you care about the colour? Do you need g/free sync? What do you use your system for?
This is actually a good pick in my opinion btw. Looks great.
preference, if you play more competitive titles, 27 is the maximum i'd go
  • CPU
    Intel i7 4770K
  • Motherboard
    ASUS Z87-K
  • RAM
    16GB Crucial DDR3 1600MHz
  • GPU
    Gainward 980ti
  • Case
    Coolermaster
  • Storage
    1TB HDD, 112GB SSD
  • PSU
    dont know
  • Display(s)
    1 ASUS PG278Q, 1 VS228N
  • Keyboard
    Ducky ONE 2 TKL Horizon PBT Gaming
  • Mouse
    Logitech G Pro
  • Sound
    Logitech G432
  • Operating System
    Win 10
  • Phone
    One Plus 7T Pro
