Radeon Manual Fan Setting always 100% after Bootup
dewod
Hello, i have msi radeon RX 5700 XT Gaming X, every bootup or restart my manual fan setting on radeon wattman (i currently use 20.8.1 driver right now), automatically turn into 100% so i should turn down to lower sepeed manually every bootup, i have save my fan setting to 60%, but every bootup the setting always reverting to 100%, i dont want my fan to spinning like jet engine everytime tho,if i leave my fan setting to automatic it only spinning on 40% max,is this a bug on the driver or it is a conflict with other apps ?, i have msi afterburner installed on my pc but i never use the fan setting so it always on default fan setting.
thanks
Use DDU to remove all traces of any Nvidia or AMD drivers from your system, then reinstall the latest drivers from the AMD site. (20.8.1 at the time of this post)
CPURyzen 7 5800X Cooler: Arctic Liquid Freezer II 120mm AIO with push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
MotherboardASRock X570M Pro4 GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO Case: Antec P5 PSU: Rosewill Capstone 750M
Monitor: ASUS ROG Strix XG32VC Case Fans: 2x Arctic P12 PWM Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
Yes im always use ddu every install of my driver, even i use the radeon factory reset, but it still reseting
